The Ultimate Buying Guide to Choosing the Right Scale Ice Maker
  • #15060
      If you’re in the foodservice, hospitality, or commercial refrigeration business, selecting the right scale ice maker is crucial to keep your operations running smoothly. In this guide, we’ll walk you through how to choose the best commercial-grade scale ice maker, with a spotlight on models like the Hisakage Scale Ice Maker (AP Series)—a professional solution tailored for business needs rather than everyday home use.
      scale Ice Maker
      What Is a Scale Ice Maker?
      A scale ice maker is a commercial machine designed to produce large quantities of ice efficiently for business environments such as restaurants, hotels, cafes, bars, supermarkets, and healthcare facilities. Unlike small household ice makers, these machines are built for continuous heavy usage and higher output, ensuring your operations never run out of ice during peak demand.
      The AP Series from HISAKAGE (e.g., AP‑0.3) produces scale ice—thin or flake-style pieces ideal for food displays, seafood counters, salad bars, and other commercial applications where rapid cooling and even distribution are key.
      Why Capacity and Ice Type Matter Most
      1. Production Capacity
      Commercial ice makers are rated by how much ice they can produce in 24 hours. Make sure the machine you choose can exceed your typical ice demand—especially during peak periods. Slightly overestimating ensures a safety buffer and continuous operation even during busy shifts.
      For larger venues like hotels or banquet halls, high-capacity machines with daily outputs above 100 kg/24 h are common. Smaller cafés or bars might find 50 kg–100 kg/day capacity sufficient.
      2. Ice Type
      Different businesses benefit from different ice shapes:
      • Scale Ice: Thin, irregular pieces that cool fast and are perfect for displays or food preservation.
      • Cube Ice: Standard for drinks in bars and restaurants.
      • Flake Ice: Excellent for salad bars and seafood displays.
      The AP Series from HISAKAGE focuses on scale ice, which is excellent for quick cooling and commercial food-related applications.
      HISAKAGE: A Trusted Commercial Manufacturer
      When buying commercial equipment, reliability and support matter as much as performance.
      HISAKAGE (Zhejiang Hisakage Equipment Co., Ltd.) is a professional manufacturer founded in 2007, specializing in commercial ice makers, refrigerators, and display cabinets. The company operates large-scale facilities with advanced production capabilities and has passed international certifications like ISO9001, CE, ETL, NSF, and ENERGY STAR—ensuring products meet global quality and safety standards.
      Their product lineup includes cube, flake, crescent, and scale ice makers, offering solutions across industries and business sizes.
      Key Features to Consider
      When comparing scale ice makers (including HISAKAGE AP Series), evaluate these factors:
      1. Ice Output & Storage
        Choose a model sized for your busiest day. Make sure production keeps up and storage allows comfortable backup supply. Some units come with integrated bins; others need external storage.
      2. Build Quality and Materials
        Look for stainless steel construction and industrial-grade components to resist corrosion and ensure long service life.
      3. Cooling System
        Air-cooled units are more common and easier to install, while water-cooled ones can be more efficient in hot kitchens—choose based on your environment.
      4. Certifications & Safety
        NSF/ANSI, CE, ETL and similar marks indicate compliance with food safety and electrical safety standards.
      5. Energy Efficiency
        Commercial machines run continuously. Investing in efficient models reduces monthly utility costs.
      6. After-Sales Support
        Warranty length, local support availability, and spare-parts access matter for reducing downtime.
      Where Scale Ice Makers Are Used
      These machines find applications in many commercial environments:
      • Restaurants and bars – ensure constant ice supply for drinks.
      • Hotels and resorts – serve guests 24/7.
      • Buffets and salad bars – display food chilled attractively.
      • Healthcare and labs – cooling and preservation.
      Final Tips Before You Buy
      • Match Output with Demand: Calculate your business’s peak ice usage and choose a model that comfortably exceeds it.
      • Choose the Right Ice Style: Scale ice works well for food and display applications, but cube or flake might be better for beverages or specific needs.
      • Prioritize Long-Term Costs: An energy-efficient machine with a good warranty often costs less over its lifetime.
      • Work with a Reliable Manufacturer: Selecting a reputable supplier like HISAKAGE gives you confidence in quality, certifications, and global support.
      Choosing the right scale ice maker doesn’t have to be confusing. Focus on your business demands, match capacity and ice type to your workflow, and pick a trusted brand backed by global certifications. Whether you run a busy restaurant, a hotel, or a foodservice operation, the right machine keeps your business running efficiently and reliably.
      http://www.hisakage.com
      HISAKAGE REFRIGERATION EQUIPMENT CO.,LTD.
