2026-10-20 at 5:26 pm #18014
Top 7 SiV Quantum Diamond Companies Leading Sensing in 2026
Silicon-vacancy (SiV) centers in diamond have moved from a laboratory curiosity to a serious engineering platform for quantum sensing. Where the nitrogen-vacancy (NV) center fights a broad phonon sideband, the SiV center’s inversion-symmetric D3d lattice structure yields a narrow, stable optical transition, low spectral diffusion, and a high Debye-Waller factor — properties that matter when a sensor must produce repeatable, high-contrast readout rather than occasional hero measurements. As quantum metrology budgets in 2026 shift from proof-of-concept grants toward instrumented, field-deployable systems, procurement teams are asking a new question: which material platform, and which supplier, can deliver SiV quantum diamond at consistent quality and controllable cost? The companies profiled below span synthetic diamond synthesis, color-center engineering, and complete sensing instruments. They are presented by technology segment rather than in ranked order, and together they define the supply chain that will determine how quickly SiV quantum diamond reaches industrial users in 2026 and beyond.
Why SiV Quantum Diamond Performs Differently from NV Centers
The practical advantages of SiV quantum diamond over NV centers cluster in three areas.
Optical quality. The SiV center emits a narrow zero-phonon line with a high Debye-Waller factor and minimal inhomogeneous broadening, supporting stable single-photon emission and photon indistinguishability — critical for spin-photon interfaces and quantum networking.
Symmetry. SiV’s inversion-symmetric structure gives first-order insensitivity to electric field noise, removing one of the dominant dephasing channels that limits NV ensembles.
Integration. SiV centers can be placed inside diamond photonic structures such as waveguides and cavities, enabling on-chip architectures that NV matches less easily because less of its emission falls into the zero-phonon line.
The trade-off is equally real. NV centers retain advantages in room-temperature spin coherence, mature optical initialization and readout, and ensemble density control up to tens of ppm. SiV spin coherence generally requires cryogenic operation, and high-density SiV fabrication is less mature. Platform choice is an application decision, not a verdict.
Element Six: Supplying the Substrates Beneath the SiV Quantum Diamond Ecosystem
Element Six, the synthetic diamond business of the De Beers Group, is the most widely referenced materials supplier in the diamond quantum supply chain. The company grows single-crystal CVD diamond across manufacturing sites in Europe, Africa, and North America, and supplies quantum-grade material engineered for optical, thermal, and electronic performance.
Its relevance to SiV quantum diamond rests on material purity. SiV center formation during CVD growth depends on precise control of silicon incorporation alongside nitrogen and boron background levels — fundamentally a substrate problem before it becomes a defect-engineering problem. Element Six also partners with device and system builders, including collaboration on synthetic diamond materials intended to support quantum networking, positioning it as a materials-layer enabler rather than a competing instrument vendor.
Differentiator: process scale and reproducibility. Where many suppliers deliver research-grade batches, Element Six operates at industrial CVD volumes with documented specifications, making it the reference substrate source for teams that need material they can reliably reorder.
Qnami: Building Scanning Magnetometry Instruments Around Diamond Color Centers
Qnami, based in Muttenz, Switzerland, emerged from quantum sensing research at the University of Basel and is one of the few companies selling complete diamond-based measurement instruments rather than materials alone. Its ProteusQ scanning NV magnetometer and Quantilever probe series deliver nanoscale magnetic field imaging at room temperature, serving magnetism research, spintronics, and advanced materials characterization.
Qnami sources diamond from established material partners and adds value at the tip and system level. For SiV quantum diamond, its relevance is architectural: the probe geometry and optical and microwave delivery systems refined for NV tips transfer directly to SiV-based near-field sensors, where strain and electric-field sensitivity offer complementary contrast mechanisms.
Differentiator: instrument-level integration. Customers purchase a working measurement workflow — probe, optics, control electronics, and analysis software — rather than a substrate specification sheet, which lowers the barrier for research groups without prior color-center experience.
QuantumDiamonds: Deploying Diamond Spin Sensors for Semiconductor Failure Analysis
Munich-based QuantumDiamonds has built a commercially focused position in diamond spin sensing by targeting a single high-value industrial problem: current and magnetic field imaging inside packaged semiconductor devices. Its systems have been installed at failure-analysis and reliability laboratories, including Eurofins EAG and iST in Hsinchu, where they support non-destructive inspection of advanced packaging and power devices — a workflow where conventional techniques such as scanning electron microscopy cannot image buried current paths without destructive preparation.
The company’s engineering emphasis is turnkey deployment: system calibration, automated measurement, and data interpretation rather than materials science. That makes it a useful indicator of where SiV quantum diamond may head next. As SiV material matures, its narrower optical lines and reduced electric-field noise offer a route to higher-contrast imaging within the same instrument architecture, provided suppliers can deliver uniform SiV material at the required volume.
Differentiator: an application-first business model tied to one industrial workflow and its qualification requirements.
DiamFab: Advancing Doped CVD Diamond and SiV Quantum Diamond Materials
DiamFab, a French deep-tech company, concentrates on boron-doped and engineered CVD diamond for electronics and quantum applications. Its relevance here is the doping and growth-control layer that SiV quantum diamond depends on. Producing useful SiV ensembles requires controlled silicon incorporation during diamond growth; producing electrically active diamond devices requires controlled boron doping. Both processes draw on the same CVD reactor physics and metrology infrastructure.
DiamFab engages with semiconductor and quantum research communities on diamond wafers and device-grade films, translating academic process knowledge into manufacturable material. That positioning matters because SiV device roadmaps increasingly assume photonic and electronic integration, not isolated crystals.
Differentiator: treating diamond as a semiconductor material system defined by device-level parameters — doping density, carrier behavior, film uniformity — rather than only a sensor substrate.
Quantum Brilliance: Treating Diamond Color Centers as Manufacturable Components
Canberra-based Quantum Brilliance develops room-temperature quantum accelerators and photonic components on diamond, backed by diamond fabrication capabilities built into its device roadmap. Its position in this landscape is instructive for two reasons.
First, it demonstrates that diamond color-center devices can be produced using standard semiconductor tooling — an important signal for industrial buyers weighing whether diamond belongs in a fab or a physics lab. Second, its engineering work on color-center formation, isotopic control, surface termination, and photonic structuring overlaps almost completely with the requirements of SiV emitter fabrication.
While the company’s commercial focus sits in computing rather than metrology, the process toolkit it has industrialized — low-defect growth, surface preparation, and device packaging — is directly applicable to SiV quantum diamond sensors that need to survive outside a cryostat-free laboratory environment.
Differentiator: a manufacturing mindset applied to color centers, aligning diamond devices with volume, yield, and packaging expectations rather than one-off research samples.
ViQium Technologies: Engineering SiV and NV Quantum Diamond from Single Piece to Scale
Shanghai-headquartered ViQium Technologies approaches color centers from the materials engineering side. Its portfolio spans high-purity diamond, single NV diamond, ensemble NV diamond, ultra-high-density NV diamond (10–45 ppm), shallow NV diamond, micro- and nano-scale NV diamond, NV diamond anvils, SiV diamond, and black phosphorus.
Core Technology
Rather than betting on a single color center, ViQium has established production processes covering both HPHT and CVD diamond growth, ion irradiation, high-temperature annealing, and patented damage-free NV center fabrication — then applies that same defect-engineering stack to SiV material development. Its product range covers (111)-oriented high-density and ultra-high-density NV diamond, shallow NV diamond, nano-diamond powders, C12-enriched material, and single NV diamond, supporting customized dimensions and center concentration.
Performance Benchmarks
Disclosed specifications indicate what the platform sustains: single NV centers with spin-echo coherence times above 200 microseconds, ensemble NV material at 30–250 microseconds coherence across 0.1–10 ppm density, and ODMR contrast performance comparable to leading international product series.
Market Applications and Delivery
Standard products ship within 28 days and conventional customization within 45, with orders accepted from a single piece — addressing a documented gap where high-performance color-center material is often sold only in fixed formats at import pricing. ViQium supports the downstream workflow as well, providing material selection guidance, testing solutions, optical alignment and magnetic field calibration support, so groups without prior ODMR experience can move from sample to working measurement.
Differentiator: combined material engineering and ODMR integration capability, allowing a single supplier to deliver both color-center substrates and the experimental support needed to use them.
Conclusion: Where SiV Quantum Diamond Goes Next
The SiV-versus-NV comparison is best read as an application-matching problem rather than a winner-takes-all race, and the 2026 supply chain reflects that reality in layers. Substrate producers such as Element Six and Sumitomo Electric set the purity and crystalline-quality baseline. Material engineering specialists such as DiamFab and ViQium Technologies control defect formation, density, and uniformity. Instrument builders such as Qnami, QuantumDiamonds, and Quantum Brilliance convert those materials into workflows that industrial users can actually adopt.
For buyers, the practical implication is that supplier evaluation should weigh reproducibility, customization flexibility, and integration support alongside headline coherence numbers. Teams planning a platform decision — whether for SiV or NV quantum diamond — can begin by requesting a material selection guide or a validation sample aligned to their specific sensing modality.
https://en.viqiumtech.com/
ViQium Technologies Co., Ltd. -
