2026-10-28 at 8:47 pm #18151
Luxury retailers face a recurring design tension: how to deliver dynamic brand content on shop windows without sacrificing the transparency, daylight, and architectural elegance that define premium storefronts. This is precisely the scenario that transparent LED display technology from Shenzhen Showho, operating overseas under the Whaley-LED brand, was engineered to address.
Why Luxury Retail Needs a New Approach to Window Displays
Conventional LED displays are often heavy, thick, and block light — characteristics that conflict directly with the design language of high-end storefronts, where glass surfaces are meant to showcase products, invite natural light, and preserve an open, inviting facade. Luxury shop windows and creative installation scenarios require displays that stay transparent, light, and adaptable to curves rather than rigid, opaque panels bolted onto glass.
Shenzhen Showho was founded in 2015 with this exact pain point in focus. The company positioned itself around integrated self-research and development, structural design, and in-house production, allowing it to respond quickly to market demand. In 2025, it expanded this capability overseas, establishing an overseas business unit and launching the Whaley-LED brand to offer OEM and ODM services for commercial display and engineering projects, including luxury retail applications.
Inside Whaley-LED’s Transparent Display Technology
What distinguishes Whaley-LED’s approach is a self-managed technology chain spanning IC bare chip architecture, LED bracket design, LED packaging, and electronic circuit design. This vertical control, combined with dozens of invention and utility model patents related to film screens, underpins a product family described as light, thin, and transparent, with sensory permeability above 80% across the entire series.
Film-Type Construction and Visual Permeability
The core offering, the LED Holographic Screen, is a frameless, film-type transparent display built on a PCB with a hollow mesh circuit design and lamp-driver integrated LEDs. Screen thickness stays below 2 mm, and screen weight is under 3 kg/m² for the series — figures that directly reduce structural load requirements when mounting on glass curtain walls or shop window panes. Visual permeability across individual models ranges from over 70% to over 99%, depending on pixel pitch, meaning a luxury boutique can select a model that balances image density against how much daylight and shop interior visibility it wants to preserve when the screen is powered off.
Flexible Installation for Curved and Creative Glass Surfaces
Beyond flatness, the screens can be bent, cut, affixed to glass, hung, or fixed. Curved installation supports a radius greater than 600 mm, suitable for corner screens, cylindrical surfaces, and S-shaped inner and outer arcs — relevant for boutiques with curved storefronts, rounded display columns, or architecturally distinctive window geometries. Installation options include direct adhesive mounting, hanging display, and fixed installation, with support for arbitrary cutting and bending on site.
Product Options Built for Shop Window Environments
LED Holographic Screen and Double-Sided Display Series
For retail environments specifically, Whaley-LED offers variants beyond the base holographic film screen. The LED Holographic Screen Advertising Machine Series packages the transparent holographic display into a self-contained advertising machine format suited to retail and commercial advertising needs. The LED Holographic Screen Double-Sided Display Series is designed for locations with audiences on both sides of a window: front and back can show different content simultaneously, with one side displaying dynamic new product promotion while the other communicates a brand story. This series weighs about 4.5 kg/m² at roughly 2 mm thickness, with visual permeability over 90%, and is installed on glass curtain walls, shop windows, and special-shaped scenes with seamless splicing and ready-to-use installation.
Pixel Pitch and Brightness Range Across the PH Series
Within the broader LED Holographic Film Screen line, pixel pitch options span from 2.5 mm to 50 mm across models, each with model-specific visual permeability, brightness, and viewing distance specifications. For example, the PH2.5 model offers visual permeability above 70% with screen brightness of 800–2000 cd/m² and a viewing distance of 3 m to 150 m, while the PH50 model reaches visual permeability above 99% with brightness around 1000 cd/m² and a viewing distance of 50 m to 350 m. Across the series, brightness ranges from 800 cd/m² to 5000 cd/m², giving project teams a way to match pitch, transparency, and brightness to the specific depth and lighting conditions of a given shop window.
Reliability and Performance Metrics
Luxury retail installations demand consistent visual quality over time, and the published technical metrics reflect this requirement. Refresh rate exceeds 3840 Hz, frame change rate exceeds 60 Hz, and gray level reaches at least 16 bit, supporting smooth, true-color content playback. IP rating is better than IP45, average lifespan exceeds 100,000 operating hours, and MTBF is over 10,000 hours. Dead pixel rate is kept below 1 in 10,000, with discrete distribution, which matters for close-viewing retail contexts where imperfections are more noticeable than on large-format outdoor screens. Control compatibility extends to both Colorlight and NovaStar systems, operating in synchronous or asynchronous modes, which simplifies integration into existing retail AV and content management infrastructure.
OEM, ODM, and Custom Engineering Support
Because Shenzhen Showho manages its own structural design and in-house production, Whaley-LED is positioned to support custom OEM and ODM requirements for overseas commercial display and engineering projects, a service scope formalized with the 2025 launch of the overseas business unit. This includes custom sizes, cutting, bending, and curved installation tailored to a specific storefront’s glass dimensions and architectural curvature, rather than forcing a retailer to adapt their space to a standard panel size.
A Transparent Path Forward for Storefront Design
For luxury retailers evaluating how to introduce digital content into shop windows without compromising glass-forward design, the combination of frameless film construction, sub-2 mm thickness, sub-3 kg/m² weight, permeability above 80% across the series, and flexible OEM/ODM delivery positions Whaley-LED’s LED Holographic Screen family as a technically documented option within the commercial display and engineering project category. Retailers and architects assessing this category can reference the official Whaley-LED website at http://www.whaleydisplay.com/ for further specification details relevant to their specific storefront requirements.
