Transparent LED Holographic Advertising Machine Wholesale
  • #18126
      Understanding the Demand for Transparent LED Holographic Advertising Machines
      Retailers, brand agencies, and commercial property owners searching for a transparent LED holographic advertising machine wholesale partner are typically solving the same problem: conventional advertising displays are heavy, opaque, and visually disruptive to glass storefronts or curated retail environments. Shenzhen Showho, operating its overseas commercial display brand Whaley-LED, addresses this exact pain point through a self-contained advertising machine built on its film-type holographic screen technology. This review examines the technical foundation, manufacturing approach, and application scope of this product line based on information published by the company.
      The Technology Behind Whaley-LED’s Holographic Advertising Machine Series
      The LED Holographic Screen Advertising Machine Series is positioned as the advertising-machine form factor of Whaley-LED’s broader LED Holographic Screen line. Rather than adapting a conventional LED panel, the product inherits the company’s film-style transparent display architecture, which was originally engineered to solve a specific industry pain point: conventional LED displays are heavy, thick, and block light, making them unsuitable for glass surfaces or creative installation scenarios that require transparency and curve adaptability.
      Core Film Screen Engineering
      Shenzhen Showho has built its advertising machine series on a self-managed technology chain that spans IC bare chip architecture and functional design, LED bracket, LED packaging, and electronic circuit design. This vertical integration is supported by dozens of invention and utility model patents related to film screens. The lamp board itself uses a PCB with hollow mesh circuit design, paired with lamp-driver integrated LED construction, allowing the screen body to remain frameless while keeping thickness below 2 mm across the film screen series.
      Key Technical Specifications
      Buyers evaluating wholesale quantities will find a consistent set of performance metrics across the holographic film screen series that underpins the advertising machine format:
      • Screen thickness: below 2 mm
      • Screen weight: under 3 kg/m²
      • Sensory permeability: over 80% across the series, with model-level visual permeability ranging from more than 70% to more than 99% depending on pixel pitch
      • Pixel pitch options: from 2.5 mm to 50 mm across models
      • Brightness range: 800 cd/m² to 5000 cd/m² across models
      • Refresh rate: greater than 3840 Hz
      • Frame change rate: greater than 60 Hz
      • Gray level: at least 16 bit
      • IP rating: better than IP45
      • Average lifespan: more than 100,000 operating hours
      • MTBF: greater than 10,000 hours
      • Dead pixel rate: less than 1 in 10,000, discrete distribution
      These specifications are consistent with the pixel-pitch model range documented for the holographic film screen line, which spans PH2.5 through PH50 configurations, each carrying its own visual permeability figure—for example, PH2.5 at greater than 70%, PH6.25 at greater than 90%, and PH50 at greater than 99%. The advertising machine format draws on this same underlying film screen engineering to deliver its transparent display effect.
      Why Wholesale Buyers Consider Whaley-LED for OEM and ODM Projects
      Shenzhen Showho operates as an integrated R&D, structural design, and manufacturing enterprise offering OEM and ODM services. This structure is central to its value proposition: because the company manages research, structural design, and in-house production under one roof, it is positioned to respond quickly to market demand and support custom OEM and ODM projects, including customized requirements for overseas commercial display and engineering projects.
      For a wholesale buyer, this matters in several concrete ways. The company’s delivery capability includes custom sizes, cutting, bending, and curved installation, with documented support for curved installation with radius R > 600 mm for corner screens, cylindrical surfaces, and S-shaped inner and outer arcs. Installation options for the holographic screen family include direct adhesive mounting, hanging display, and fixed installation, with arbitrary cutting and bending supported on-site. Control compatibility extends to Colorlight and NovaStar systems, operating in either synchronous or asynchronous mode, which simplifies integration into existing commercial display networks.
      Industry Applications and Deployment Flexibility
      The holographic screen family, including the advertising machine series, is documented as suited to commercial display windows, commercial curtain walls, exhibition halls, creative displays, entertainment and cultural tourism, automobile 4S stores, airport concourses, building curtain walls, and commercial centers. For the advertising machine configuration specifically, Shenzhen Showho positions the product toward retail and commercial environments needing self-contained transparent advertising displays, with industry adaptation described as commercial advertising and retail.
      This differs from the double-sided display variant in the same product family, which is built for locations with audiences on both sides or two different communication needs in one display, enabling independent content on front and back simultaneously. While the advertising machine series is a distinct product, both draw on the same underlying holographic visual effect, which the company describes as delivering stereoscopic and vivid pictures with bright colors when the display is active, while allowing daylight to pass through unaffected when the unit is off.
      Manufacturing Capability and Quality Assurance
      Founded in 2015 and headquartered in Shenzhen, China, Shenzhen Showho built its early business around the domestic high-end rental display market, including XR virtual shooting screens and carbon fiber rental screens. In 2025, the company established an overseas business unit and launched the Whaley-LED brand specifically to extend OEM and ODM services for commercial display and engineering projects to international customers.
      This background is relevant to wholesale sourcing decisions because it reflects a company that has scaled its manufacturing discipline from rental-market precision requirements into a broader commercial display and advertising machine portfolio. The self-developed IC with strong driving performance, combined with controlled component sourcing across the LED bracket, LED packaging, and electronic circuit design stages, supports the consistency of specifications such as attenuation rate less than 0.05% within 2 years that are documented across the pixel-pitch model range feeding into the advertising machine series.
      Final Assessment
      For organizations evaluating a transparent LED holographic advertising machine wholesale source, the documented combination of frameless, light, thin, bendable, and cuttable screen design, patent-backed film screen engineering, OEM and ODM manufacturing flexibility, and a defined set of measurable technical parameters positions Whaley-LED, operated by Shenzhen Showho, as a manufacturer whose advertising machine series is built on the same vertically integrated technology stack the company applies across its full holographic and transparent display catalog. Buyers sourcing at wholesale volume can reference these published specifications directly when comparing pixel pitch, permeability, and installation requirements against their specific retail or commercial advertising use case.
      http://www.whaleydisplay.com/
      Shenzhen Showho (Whaley-LED)
