Tray Dryer: How to Achieve Stable Moisture Control, Uniform Drying, and Energy Efficiency in Industrial Production
  • #16117
      In industrial drying projects, Tray Dryers are still one of the most commonly used batch drying systems across pharmaceuticals, chemicals, food processing, and specialty materials.
      What’s interesting is that although the equipment itself looks relatively simple, achieving stable and uniform drying in actual production is often much more difficult than expected.
      A lot of factories run into issues like:
      • Uneven drying between trays
      • Long drying cycles
      • Product discoloration or degradation
      • High energy consumption
      • Moisture inconsistency between batches
      And in many cases, the problem isn’t necessarily the Tray Dryer itself — it’s the airflow design, thermal distribution, loading method, or process control strategy behind it.
      One thing that stands out in real applications is how critical airflow management is.
      Even small differences in airflow velocity between tray levels can create major moisture differences in the final product. Air naturally follows the path of least resistance, so trays near the air inlet often dry much faster than trays further downstream.
      That’s why more advanced Tray Dryer systems now use:
      • Balanced airflow distribution
      • Optimized duct and baffle structures
      • Reversible airflow systems
      • Multi-point thermal monitoring
      In practice, airflow uniformity often matters more than simply increasing temperature.
      Another issue many operators overlook is material behavior itself.
      Drying isn’t just about surface evaporation. For many products, especially gels, pastes, or dense materials, internal moisture diffusion becomes the limiting factor during later drying stages.
      A common mistake is compensating by increasing temperature too aggressively, which can cause surface hardening or “case formation” — where the outer layer dries too quickly and traps moisture inside.
      That usually leads to longer drying time instead of shorter.
      Energy efficiency is another major discussion point.
      Traditional Tray Dryers often lose a large amount of heat through exhaust air. Modern systems improve efficiency by optimizing the balance between fresh air intake and air recirculation, while some higher-end configurations also integrate heat recovery systems.
      From an operational perspective, loading configuration also has a surprisingly large impact.
      Tray spacing, material thickness, and loading density all directly affect airflow penetration and heat transfer performance. Overloading trays is still one of the most common reasons for uneven drying in production environments.
      What I find most interesting is that the industry is gradually shifting its view of Tray Dryers.
      They’re no longer treated as just “hot cabinets,” but more as controlled thermal processing systems where airflow dynamics, heat transfer, moisture migration, and automation all interact together.
      Companies working on customized thermal systems, such as FAB Stanley Trading (Shanghai) Co., Ltd, are increasingly focusing on system-level optimization rather than simply increasing heating capacity.
      At the end of the day, modern industrial drying is less about whether moisture can be removed, and more about how consistently, efficiently, and precisely the process can be controlled.
      Curious to hear how others here deal with airflow balancing and drying consistency issues in real production environments.
      http://www.fabstanley.com
