Triple filtration and efficient purification | New product release of Bodi Honor HCY-W6 centrifugal oil mist collector
  • #12916
      In industrial production, workshops often generate large amounts of oil mist,
      micro mist, and smoke due to the use of cutting fluid, coolant, and lubricating
      oil, which not only endangers the health of employees but also poses potential
      damage to equipment. To solve these problems, the Bodi Honor HCY-W6 centrifugal
      oil mist collector has made a new appearance, creating an environmentally
      friendly and safe production environment for enterprises.
      Efficient filtration principle: Triple filtration layer by layer
      purification
      HCY-W6 adopts an innovative triple filtration system to ensure that oil mist
      particles are purified layer by layer from large to small, ultimately achieving
      efficient air cleaning.
      1. Inlet: Optimize airflow distribution
      Horizontal air intake design ensures that oil mist particles are evenly
      dispersed into the equipment, laying the foundation for subsequent filtration.
      Sealed design prevents leakage and ensures equipment operational efficiency.
      2. Initial filtration section: 20mm metal wire mesh filter
      Intercept large particles of oil mist and droplets to achieve preliminary
      separation. The metal wire mesh filter can be cleaned and reused, improving
      equipment economy, while recycling coolant and reducing waste.
      3. Medium efficiency filtration section: F5~F8 medium efficiency filtration
      cotton
      Effectively filters medium-sized particles and provides protection for
      high-efficiency filters. Different filtration levels can be selected according
      to needs, balancing purification efficiency and consumable costs.
      4. High efficiency filtration section: HEPA high-efficiency filter (H13
      level)
      Capture ultrafine particles of PM2.5 and below, with a filtration efficiency
      of up to 99.9%. Meet the purification standards of cleanroom level and
      comprehensively improve the air quality in the workshop.
      5. Brushless fan: capable of infinite speed regulation
      Support infinite speed regulation, adjust air volume according to actual
      working conditions, balance energy consumption and performance. The fan operates
      without friction and has a low noise level of ≤ 65dBA, providing a quiet
      operating environment for the workshop.
      Highlights and core advantages of Bodi Honor HCY-W6
      1. Harting connector: a new choice for intelligent industry
      Modular design: supports multiple sizes and pin numbers, and can
      simultaneously meet the needs of power, signal, and data transmission.
      High protection level: Excellent waterproof and dustproof performance,
      suitable for various harsh environments, ensuring long-term stable operation of
      the system.
      Easy to install and expand: Flexible interface design, supporting quick
      installation and disassembly, suitable for the expansion needs of complex
      production systems.
      2. Energy saving and environmentally friendly, quiet operation
      Brushless fan technology not only reduces operating energy consumption, but
      also controls noise within ≤ 65dBA, improving the workshop environment. The
      filter has a lifespan of up to 8-12 months, reducing maintenance frequency and
      consumable costs.
      3. Flexible installation, adaptable to various working conditions
      Provide two options for top installation and side installation to meet
      different workshop layout requirements. Support multiple accessory extensions
      (such as pipeline systems, electrical control systems, etc.) to optimize the
      user experience.
      4. Durable and easy to maintain
      Alloy steel shell, designed for a service life of up to 20 years. Lock lock
      hinge door design, quickly complete filter element replacement, saving time and
      effort.
      Whether it is conventional machining of lathes and milling machines, or
      high-precision grinding and gear machining, this small centrifugal oil mist
      collector can provide efficient oil mist purification effect, meet the needs of
      various equipment and scenarios, and assist in the construction of
      environmentally friendly production and healthy workshops.
      Let HCY-W6 become the environmental guardian of your workshop, helping
      enterprises achieve higher production prices
      http://www.bodhicollector.com
      Wuxi BODHl Environmental Technology Co., Ltd.
