U.S. Patent Safeguards Pharmaceutical Cleanroom Production Lines: Hengxiang Hongye Pioneers a New Approach to Non-Destructive and Controllable Settlement Remediation in GMP Facilities
  • #18596
      Abstract: The U.S. invention patent led by Beijing Hengxiang Hongye Foundation Reinforcement Technology Co., Ltd., Lifting and Reinforcing Process for Dust-Free Factory Floor (Chinese title: A Lifting and Reinforcement Process for Dust-Free Factory Floors, International Application No. PCT/CN2023/079305), addresses the problem of dust generation and secondary contamination caused by settlement in GMP facilities through a targeted lifting process using rubber bladders. The patented process has been successfully applied in a 5,078 m² pharmaceutical packaging facility in Qingpu District, Shanghai, where settlement remediation was completed without interrupting production. Supported by its overseas branches, the company can provide floor lifting solutions for precision facilities in the pharmaceutical, electronics, and new energy industries worldwide without compromising the overall integrity of the facilities.
      I. The Challenge: Secondary Contamination Caused by Conventional Reinforcement in Pharmaceutical Cleanroom Facilities
      Clean facilities in the pharmaceutical, food, and medical device industries are subject to stringent zoning controls for dust, temperature, humidity, and microorganisms. Once differential floor settlement occurs, conventional drilling-based construction inevitably requires breaking through the floor.
      Dust generated by drilling operations and grout leakage along boreholes can create contamination risks. Repair gaps left after hole sealing may form invisible pathways through which external dust enters clean areas.
      As a result, companies face a dilemma: on the one hand, they must bear substantial financial losses caused by production shutdowns; on the other hand, they must incur high costs for secondary dust-cleaning operations after repairs are completed.
      II. Patented Process: Consolidation First, Precision Lifting Second—Maintaining the Cleanliness Threshold
      The process covered by this U.S. invention patent consists of two steps.
      Step 1: Reinforcement of Weak Soil. Stable consolidated soil bodies are formed within weak soil layers beneath the settlement-affected area, increasing the foundation bearing capacity to the required design level.
      Step 2: Precision Lifting of the Settled Area. The settlement-affected area is precisely lifted using rubber bladders to create an enclosed lifting system, without compromising the integrity of the existing floor. The rubber bladders act as sealed chambers, confining grout within the designated lifting area and concentrating upward lifting force while preventing ineffective grout dispersion into the underlying foundation soil.
      Upon completion of the coordinated two-step process, the floor is restored to its designed elevation. The structural integrity of the facility remains intact, and the cleanroom environment is not disturbed.
      III. Core Advantages: Turning Patented Technology into Cleanroom Protection
      • Targeted Lifting with Rubber Bladders: Rubber bladders serve as enclosed chambers that confine grout within the designated lifting area, preventing grout from dispersing in multiple directions and ensuring that lifting force is applied only to the intended location.
      • Preserving the Overall Integrity of the Facility: All operations are carried out within the underlying foundation soil, without extensive demolition of the floor surface, cutting off dust pathways at their source.
      • Foundation Remediation and Capacity Expansion in Parallel: Bearing capacity can be improved during construction to meet the load requirements of newly installed equipment and future production capacity expansion.
      IV. Project Application: Settlement Remediation of a 5,078 m² Pharmaceutical Packaging Facility in Qingpu, Shanghai
      A pharmaceutical packaging facility in Qingpu District, Shanghai, experienced differential settlement, with a maximum settlement of 40 mm. The site geology consisted primarily of cohesive soil, silty sandy soil, and sandy silt. The building was supported by pile-and-cap foundations, occupied an area of 5,078 m², and had a structural height of 13.7 m.
      The floor settlement was caused by insufficient bearing capacity of the original foundation soil. The facility subsequently planned to install three additional pieces of equipment with a combined weight of approximately 20 metric tons. Without remediation, the additional loads would exceed the floor's bearing capacity and further increase the risk of settlement.
      The project employed the patented lifting and reinforcement process in combination with non-destructive, controllable soil solidification technology. The shallow soil layers were solidified to form a raft-shaped composite ground reinforcement body, followed by the construction of a composite pile foundation system. Together, these systems were designed to support the loads from the superstructure.
      The entire process was conducted without breaking or dismantling the existing floor. Dust-free construction and directional precision lifting were implemented, with an intelligent monitoring system providing millimeter-level lifting control. Production continued uninterrupted throughout the project.
      After 30 days of construction, the floor had been lifted by a cumulative total of 40 mm. Both the bearing capacity improvement and lifting-level correction passed acceptance inspection in a single attempt.
      Client Feedback: “Our workshop is quite special and cannot tolerate large amounts of dust. This construction method caused no disruption, generated no dust, took a relatively short time, and delivered good results.”
      V. Intellectual Property and Global Expansion: International Patent Portfolio Supporting Cleanroom Facilities Worldwide
      Hengxiang Hongye, the patent holder, has specialized in foundation reinforcement and treatment for 20 years. The company has led the development of one corporate technical standard and is an industry-academia-research partner of China University of Geosciences (Beijing) and China University of Mining and Technology (Beijing).
      Its core technologies have undergone evaluation by the Ministry of Science and Technology and have been rated as “internationally advanced overall, with certain aspects reaching an internationally leading level” (Certificate No. 202311ZK7875).
      The company is accelerating its international expansion and global intellectual property strategy. It has accumulated a total of 148 domestic and international patent applications and granted patents, including 32 international patents (both pending applications and granted patents), and published 14 academic papers, 9 of which are indexed by SCI.
      The company has established in-depth partnerships with multinational corporations such as Mercedes-Benz, 3M, and Nestlé, as well as leading domestic companies including CATL, Geely, and Haier. Its overseas operations span multiple countries worldwide, enabling it to provide solutions to foundation settlement challenges globally.
      VI. Looking Ahead: Integrating Settlement Remediation into the Cleanroom Compliance Framework
      Cleanroom facilities have virtually zero tolerance for contamination risks, and any contamination incident may lead to serious compliance risks.
      This U.S. invention patent upgrades conventional demolition-based settlement remediation into a dust-free, clean reinforcement and restoration process that preserves the overall integrity of the facility and supports cleanroom compliance requirements.
      Going forward, Hengxiang Hongye will use this patent as a core technology, integrating non-destructive and controllable soil solidification technology, its global patent portfolio, and its overseas branch network to promote the implementation of cleanroom floor lifting and reinforcement solutions in more GMP facilities worldwide, helping safeguard clean manufacturing environments and safe production operations.
      en.hengxianghongye.com
      Hengxiang Hongye
