2026-03-13 at 5:57 pm #15538
https://www.pytesess.com/industry/V16-High-Performance-Wall-Mounted-Battery.html
As solar energy adoption accelerates, the demand for dependable and efficient energy storage systems continues to grow. Residential and light commercial installations often require batteries that combine high energy capacity, strong outdoor protection, and flexible installation options. The V16 High-Performance Wall-Mounted Battery from Pytes Energy Storage Systems is designed to meet these requirements, providing reliable energy storage for modern solar systems.
High Energy Capacity and Strong Power Output
The V16 battery delivers a nominal energy capacity of 16.07 kWh at 51.2 V, making it suitable for a wide range of applications. Its design supports a maximum continuous output power of 10.24 kW (200A), allowing it to handle typical household and small commercial loads with ease.
This combination of high energy and high power ensures that the V16 battery can maintain a stable power supply for essential systems such as lighting, appliances, and small commercial equipment. Its large capacity also allows homeowners and businesses to maximize solar self-consumption and reduce reliance on the electrical grid.
Rugged Outdoor Design
The V16 battery is built to withstand harsh outdoor conditions, eliminating the need for specialized enclosures in many installations. Its IP66-rated enclosure provides excellent protection against dust and water ingress, making it suitable for outdoor wall-mounted or ground-mounted installations.
Additionally, the battery features a built-in heating system, ensuring stable performance in low-temperature environments. These design elements make the V16 a dependable solution for installations in challenging climates where temperature variations could impact performance.
Integrated Safety Architecture
Safety is a core feature of the V16 battery. It incorporates a multi-layered safety system designed to protect both the battery and its surroundings:
Integrated DC breaker for safe disconnection and maintenance
Front-end charging circuit to prevent overcurrent issues
Aerosol fire suppression system for additional protection in the unlikely event of a fault
These features reduce the need for additional external components, simplify system design, and enhance overall operational safety.
Flexible Installation Options
The V16 battery supports both wall-mounted and ground-mounted installations, providing flexibility for different project layouts. Its compact design allows installers to maximize available space, while easy commissioning features streamline setup and integration with existing systems.
This flexibility makes the V16 battery suitable for a variety of residential and light commercial installations, including locations with limited space or specific structural requirements.
Broad Inverter Compatibility
To simplify system integration, the V16 battery supports multiple communication protocols:
RS485
CAN
WiFi
Dry contact
These interfaces allow the battery to connect seamlessly with a wide range of solar inverters and energy management systems, enabling real-time monitoring, optimized charging strategies, and enhanced system efficiency.
Long Cycle Life and Certified Reliability
The V16 battery is engineered for longevity and dependable performance. Key reliability features include:
Up to 8,000 cycles, ensuring a long service life
Multiple international certifications, including UN38.3, CE, IEC62619, UL1973, UL9540/UL9540A, CEC, and SGIP
10-year warranty, providing confidence for residential and commercial users
These credentials reflect the battery’s high-quality design and suitability for professional solar energy projects.
Typical Applications
The V16 battery is designed to serve a range of energy storage applications:
Residential Solar Energy Storage: Store excess solar energy during the day and provide power at night or during outages, increasing energy independence and reducing electricity costs.
Light Commercial Installations: Support essential systems in small businesses, offices, and retail stores, ensuring reliable operations and backup power.
Off-Grid Systems: Provide dependable energy storage for remote homes, cabins, or facilities without reliable grid access.
Its combination of high energy capacity, outdoor durability, and flexible installation makes it a versatile solution for multiple scenarios.
The V16 High-Performance Wall-Mounted Battery combines high energy capacity, robust outdoor protection, integrated safety features, and flexible installation options. Engineered for residential and light commercial solar applications, it offers reliable, long-lasting, and efficient energy storage.
By addressing common challenges in solar installations—such as outdoor exposure, limited space, and system compatibility—the V16 battery provides installers and end-users with a dependable solution that ensures uninterrupted power supply, long-term reliability, and ease of integration.
Pytes -
