2024-12-05 at 1:38 pm #10881
ARKON Bluetooth Speaker BSP1582 is one of the wireless speaker products designed and produced by ARKON, a leading OEM/ODM headphone manufacturer.The following is an introduction to the advantages and design highlights of ARKON Bluetooth Speaker BSP1582.
If you need to know more about Wireless Speaker BSP1582 or place a wholesale order after browsing this article, you can contact ARKON. Additionally, we can also provide you with OEM/ODM wireless speaker services according to your specific requirements.
The Design Highlights of the ARKON Bluetooth Speaker BSP1582
1. NFC Ease Pairing
One of the highlights of the AKRON Bluetooth speaker BSP1582 is its NFC (Near Field Communication) technology, which allows it to quickly and easily pair with compatible devices without the hassle of traditional Bluetooth pairing.
2. For Both Indoor and Outdoor Uses
One of the highlights of ARKON Bluetooth Speaker BSP1582 is the dual-use indoor and outdoor. Functionally, it can play music stably in indoor bedroom and living room, and outdoor park and beach without space limitation. In terms of convenience, there is no need to prepare separate devices for different environments, so it is easy to carry. In terms of user experience, it can not only create a private music space indoors, but also add vitality outdoors, meeting the user's needs for music in different environments, making it an ideal choice for most people.
3. Direct 3.5mm Audio Line-in
The ARKON Bluetooth Speaker BSP1582 features a direct 3.5mm Audio Line-in, providing users with two connection options. In addition to Bluetooth connection, 3.5mm audio line-in can be directly connected to devices that do not support Bluetooth connection to easily achieve audio transmission.
The Advantages of the ARKON Bluetooth Speaker BSP1582
1. Large Driver Unit:Φ102mm
The ARKON Bluetooth Speaker BSP1582 is equipped with a larger 102mm driver unit that helps to enhance the bass effect, making the low-frequency part of the music more powerful and deeper, making the rhythmic music more infectious. In the mid-high frequency, it can ensure the clarity and brightness of the sound, restore the details of the singer's voice and the sound of musical instruments, and bring users a rich, full and delicate auditory feast.
The Specification of the ARKON Bluetooth Speaker BSP1582
1. Transmission mode: Bluetooth
– The ARKON Bluetooth speaker BSP1582 uses Bluetooth as the transmission mode, which can achieve wireless connection with compatible devices such as smartphones, tablets, laptops, etc.
2. Driver Unit: ф102mm
-The ARKON Bluetooth Speaker BSP1582 has a ф102mm driver unit, which can provide stronger bass and clearer overall sound.
3. S/N Ratio:80dB
– The ARKON Bluetooth Speaker BSP1582 has a signal-to-noise ratio of 80dB, which effectively reduces interference and improves sound clarity.
4. Operating time: 6 hours
-The ARKON Bluetooth Speaker BSP1582 has an operating time of 6 hours, making it suitable for daily use.
5. Operating voltage: DC 5V/1.5A
-The ARKON Bluetooth Speaker BSP1582 operates on DC 5V/1.5A and is suitable for most power environments.
6. Weight: 1Kg
– The ARKON Bluetooth Speaker BSP1582 weighs 1kg, making it easy to carry and move around.
7. Waterproof level: PX3
-The ARKON Bluetooth Speaker BSP1582 is waterproof to a PX3 rating, which makes it resistant to moisture to a certain extent.
8. Distortion: 2%
-With distortion as low as 2%, the ARKON Bluetooth Speaker BSP1582 ensures pure sound quality.
About ARKON
ARKON is a factory dedicated to producing high-quality headphones with more than 35 years of headphone manufacturing experience. We offer OEM/ODM cooperation with various types of headphones, including wireless TV headphones, wireless headphones for seniors, Bluetooth headphones, infrared teaching headphones, over-ear headphones, etc.
In conclusion, the AKRON Bluetooth Speaker BSP1582 has a range of advantages that make it a top choice for portable audio. The Bluetooth Speaker BSP1582 features NFC for easy pairing and two connectivity options. The AKRON Bluetooth Speaker BSP1582 also has advantages such as a built-in handle for easy portability and a large driver unit for excellent sound quality.
If you are looking for a reliable, high-quality audio solution, then the AKRON Bluetooth Speaker BSP1582 is worth your consideration.
E-mail:info@arkon.com.hk
http://www.arkon.com.hk
Uni-Art Precise Products Ltd. -
