2026-06-10 at 3:26 pm #16384
Aluminum Die Casting vs. Sand Casting: What Are the Key Differences?
Introduction
Recently, many customers and industry friends have been asking about the differences between aluminum die casting and aluminum sand casting. Although both processes are widely used in manufacturing aluminum components, their production principles, costs, and applications differ significantly. Let’s take a closer look.
Working Principle Comparison
In the aluminum die casting process, molten aluminum is injected into the mold cavity under external pressure. This pressure-driven filling method allows the metal to rapidly occupy every part of the mold, resulting in precise and consistent castings.
In contrast, aluminum sand casting relies primarily on the gravitational force generated by the molten metal itself. The metal flows into the mold cavity through the pouring system, and the filling pressure depends on the height of the sprue. Because the pressure is relatively low, the filling and solidification process generally takes longer. At the same time, the overall manufacturing process is simpler and less expensive than die casting.
Advantages and Disadvantages of Aluminum Die Casting
Advantages
Excellent dimensional accuracy and surface quality.
High production efficiency, making it ideal for large-volume manufacturing.
Thin-wall components can be produced, with wall thicknesses often below 1 mm.
Good consistency between batches of products.
Disadvantages
Significant investment in casting equipment.
High mold manufacturing costs.
Die casting molds require standard or customized mold bases.
Mold cores are typically made from hot-work tool steels such as H13 and require heat treatment, increasing production expenses.
Advantages and Disadvantages of Aluminum Sand Casting
Aluminum sand casting uses the natural weight of molten aluminum to fill the mold cavity.
Advantages
Suitable for producing parts with complex shapes and structures.
Lower equipment investment compared with die casting.
Relatively low tooling and mold costs.
Flexible production process, especially for small batches and customized parts.
Disadvantages
Lower dimensional precision and surface finish than die-cast products.
Since there is no external pressure during filling, wall thickness is generally limited to 3 mm or more.
Production efficiency is typically lower than die casting.
Both aluminum die casting and aluminum sand casting have their own strengths and limitations. Die casting is better suited for high-volume production requiring high precision and thin-wall designs, while sand casting offers greater flexibility and lower upfront costs for complex or low-volume components. Choosing the right process depends on factors such as product design, production quantity, quality requirements, and budget.
We hope this comparison helps you better understand the differences between these two aluminum casting methods and select the most suitable manufacturing solution for your project.
http://www.zhongli-hardware.com
Jiangxi Zhongli Hardware Die-Casting Co., Ltd. -
