2024-11-04 at 2:49 pm #10680
Feed mixer is one of the commonly used equipment in the animal husbandry industry. Its main function is to mix and stir various feed raw materials to ensure that livestock and poultry can get balanced nutrition. However, in actual use, we often encounter uneven feed mixing, which not only affects the quality of feed, but may also have an adverse effect on the health of animals. So, what are the reasons for uneven mixing of feed mixers?
1. Equipment factors
Irrational design of the mixer: Parameters such as the shape, size and speed of the mixer have a great influence on the mixing effect. If the mixer is not designed reasonably, such as inappropriate blade angle, too large or too small blade spacing, etc., it may cause uneven mixing.
Severe wear of the mixer: After long-term use, the blades of the mixer may be severely worn, resulting in a decrease in the mixing effect. At this time, the mixer needs to be replaced or repaired in time.
Transmission system failure: The transmission system of the feed mixer includes components such as motors, reducers, and couplings. If these components fail, such as insufficient motor power, damage to the reducer, loose couplings, etc., uneven mixing may occur.
Aging of seals: The seals of the feed mixer will gradually age during use, resulting in leakage. If the leakage is serious, it will affect the mixing effect. Therefore, the seals need to be checked and replaced regularly.
2. Operational factors
Incorrect feeding sequence: The feeding sequence has a great influence on the mixing effect. Generally speaking, raw materials with larger specific gravity should be put in first, and then raw materials with smaller specific gravity; dry raw materials should be put in first, and then wet raw materials. If the feeding sequence is incorrect, it is easy to cause uneven mixing.
Too much or too little feeding: Too much feeding will cause the mixer to be overloaded and affect the mixing effect; too little feeding will cause the mixer to run idle and waste energy. Therefore, the feeding amount should be reasonably controlled according to the specifications and actual needs of the feed mixer.
Insufficient or too long mixing time: The mixing time has a great influence on the mixing effect. Generally speaking, the mixing time should be controlled within an appropriate range to ensure that the feed is mixed evenly. If the mixing time is insufficient, it is easy to cause uneven mixing; if the mixing time is too long, it may cause problems such as overheating and oxidation of the feed.
The operator's technical level is not high: The operator's technical level directly affects the use effect of the feed mixer. If the operator does not understand the performance of the equipment, is unskilled in operation or is careless, it may cause uneven mixing. Therefore, the training and management of operators should be strengthened.
3. Raw material factors
Large differences in raw material particle size: Large differences in raw material particle size will lead to uneven mixing. Because raw materials with larger particle size are easy to form lumps during mixing, it is difficult to fully mix with other raw materials. Therefore, the raw materials should be screened before using the feed mixer to mix raw materials with similar particle sizes.
Different moisture content of raw materials: Different moisture content of raw materials will also affect the mixing effect. Raw materials with higher moisture content are easy to adhere to the mixer, resulting in uneven mixing; raw materials with lower moisture content are easy to fly and scatter. Therefore, before using the feed mixer, the raw materials should be dried or the moisture content should be adjusted to an appropriate range.
Large differences in raw material properties: Large differences in raw material properties will also affect the mixing effect. For example, some raw materials have strong hygroscopicity, viscosity or electrostatic properties, which will cause the raw materials to adhere to or repel each other during mixing, resulting in uneven mixing. Therefore, when selecting raw materials, try to choose raw materials with similar properties for mixing.
4. Environmental factors
Too high or too low temperature: Temperature has a great influence on the working effect of the feed mixer. Too high temperature can cause problems such as overheating and oxidation of feed; too low temperature can cause problems such as agglomeration and coagulation of feed. Therefore, when using a feed mixer, the ambient temperature should be controlled to ensure the normal operation of the equipment.
Humidity is too high or too low: Humidity also has a great impact on the working effect of the feed mixer. Excessive humidity can cause problems such as dampness and mold in the feed; too low humidity can cause problems such as dryness and dust in the feed. Therefore, when using a feed mixer, the ambient humidity should be controlled to ensure the normal operation of the equipment.
Poor air quality: Poor air quality can cause problems such as contamination and deterioration of the feed. Therefore, when using a feed mixer, the air should be kept fresh and clean to avoid contamination of the feed.
In short, there are many reasons for uneven mixing of feed mixers, including equipment factors, operating factors, raw material factors and environmental factors. In order to ensure the normal operation of the feed mixer and the stable improvement of feed quality, we should start from many aspects and take effective measures to solve these problems. Only in this way can we ensure the normal operation of the feed mixer and improve the mixing uniformity of the feed, thereby contributing to the development of the animal husbandry industry.
As a feed mixer corporation, FAST is committed to providing efficient and uniform mixing solutions. Through the well-designed mixer structure, optimized operation process and strict raw material screening, we ensure that each batch of feed can achieve the ideal mixing effect. Our equipment adopts advanced technology, combined with years of industry experience, and can handle raw materials of various particle sizes and moisture, and can maintain excellent performance even under extreme environmental conditions. Choosing our products, you will get a reliable and efficient feed processing experience.
https://www.fast-js.com/
Jiangsu FAST Intelligent Equipment Co., Ltd. -
