What Holds a Football Field Together? The Details Behind Quality Infill Turf
  • #18428
      The performance of an artificial football field depends on more than the grass fibers visible on the surface. In an infill system, the relationship between turf yarn, backing, silica sand, and rubber granules determines how the playing surface is constructed and maintained. If these components are not properly matched, the field may experience uneven infill distribution, fiber lodging, or inconsistent playing conditions.
      For sports facility developers, contractors, and turf distributors, choosing an infill football turf manufacturer means evaluating both the artificial grass product and the manufacturer's ability to support the complete turf system. At Shuangzhu, we provide football turf in different fiber designs, together with related materials and project support for sports surface applications.
      infill soccer turf manufacturer
      Why Infill Construction Requires More Than Good Turf Yarn
      Infill football turf uses loose materials placed between the grass fibers. Silica sand and rubber granules are commonly used for different functions within the system.
      Silica sand helps stabilize the turf structure and supports the fibers near their base. Rubber granules provide additional cushioning and contribute to the surface response under player movement. Together, these materials work with the grass fibers to form the playing surface.
      The performance of the system depends on several factors:
      • Fiber structure: Determines the physical profile of the grass blades and influences how they respond to repeated use.
      • Pile height and density: Affect the available space for infill and the overall turf construction.
      • Backing: Holds the tufted fibers in position and contributes to the dimensional stability of the turf.
      • Infill specification: The material type, particle characteristics, and installation quantity need to match the selected turf system.
      • Installation quality: Consistent infill distribution is important for maintaining a uniform surface.
      This is why an infill football turf manufacturer should understand how the turf construction relates to the materials used during installation, rather than focusing only on the appearance of the finished grass.
      Choosing a Turf Structure for the Intended Application
      Different fiber designs provide different product options for football field projects. At Shuangzhu, our football turf range includes S-shaped, wave-shaped, monofilament, and diamond-shaped designs.
      S-shaped football turf is one of our available configurations. Its curved fiber profile is designed to support fiber resilience and help the grass recover after being stepped on. A typical product specification includes:
      • Pile height: 50 mm, customizable within 40–60 mm
      • Yarn material: PE
      • Gauge: 5/8 inch
      • Density: 10,500, with customization available
      • Backing: PP + net cloth + SBR coating
      • Roll dimensions: 2 m × 25 m or 4 m × 25 m
      • Color: Green, with customization available
      These specifications describe a particular S-shaped model. They should not be treated as universal specifications for every football turf product.
      For an infill installation, buyers should confirm that the selected pile height, fiber construction, backing, and infill requirements are compatible. The appropriate configuration also depends on the field's intended use and the technical requirements of the project.
      Rubber Granules and Other Materials in the Supply Plan
      Rubber granules are an important component of many infill football turf systems. However, selecting the right material involves more than choosing a granule product. Its characteristics and intended application should be checked against the turf manufacturer's recommendations and the project specification.
      Our product range includes artificial turf, turf yarn, rubber granules, and other sports flooring materials. This gives contractors and distributors the opportunity to discuss related purchasing requirements alongside the main turf product.
      For projects requiring several material categories, early coordination can help clarify which products are needed, how they relate to the selected turf construction, and what should be included in the installation plan.
      We also provide project support covering design planning, customized production, global logistics, and 3D paving guidance. The specific materials and services required can be confirmed according to the project scope.
      Testing Standards That Help Buyers Evaluate Turf Quality
      Technical documents are important when purchasing sports turf for schools, training facilities, community fields, and commercial venues. They provide measurable information that can support product evaluation and tender preparation.
      At Shuangzhu, our available documentation includes relevant CE, RoHS, REACH, and SGS-related records, alongside testing under applicable European standards.
      Several standards are particularly relevant to football turf:
      EN 15330-1:2013 – Synthetic Sports Surface Performance
      This standard establishes requirements for synthetic sports surfaces used in sports applications. It provides a reference for evaluating whether a product or system meets the relevant technical requirements.
      EN 14836 – Artificial Weathering
      UV exposure is an important consideration for outdoor football fields, particularly in regions with strong sunlight. Our applicable test documentation includes artificial weathering results exceeding 5,000 hours. This provides evidence under controlled laboratory conditions, but the result should not be converted directly into a guaranteed number of outdoor service years.
      EN 12228:2013 – Joint Strength
      The seams between turf rolls are critical parts of an installed field. EN 12228 provides testing methods for evaluating the strength of synthetic turf joints. Buyers can use relevant test documentation to assess the suitability of the joining system for their project requirements.
      Our SGS-related testing also covers areas such as heavy metals, REACH-SVHC substances, flame retardancy, UV resistance, phthalates, and PAHs. RoHS and REACH documentation addresses relevant restricted substances and chemical requirements.
      One important distinction is that EN 13672 concerns abrasion testing for non-infilled synthetic turf. It should not be presented as an abrasion result for an infill football turf model unless the specific product and test documentation establish that applicability.
      For international procurement, buyers should check the tested product, report scope, and applicable requirements before submitting technical documents for approval.
      What to Check Before Ordering from a Manufacturer
      A clear purchasing specification helps prevent misunderstandings between product selection and final delivery. Before placing an order, project buyers should review several details with the manufacturer:
      1. Turf construction: Confirm the fiber design, pile height, gauge, density, and backing.
      2. Infill requirements: Identify the specified infill materials and installation requirements for the selected system.
      3. Roll dimensions: Check the available widths and lengths against the field layout.
      4. Customization: Confirm color and other agreed product adjustments.
      5. Technical documentation: Request the applicable test reports and conformity documents for the selected model.
      6. Order preparation: Confirm samples where required, packaging, inspection arrangements, and delivery details.
      Established in 2006, Shuangzhu has developed a product range covering football, golf, and landscape turf, alongside other sports flooring materials. Our manufacturing experience and configurable product options support different purchasing requirements, from individual field projects to distributor orders.
      Building a Better Infill Football Turf Specification
      A reliable football field starts with a turf system in which the grass fibers, backing, infill materials, and installation requirements are considered together. Selecting products based only on pile height or appearance can leave important technical questions unanswered.
      As an infill football turf manufacturer, Shuangzhu offers different football turf constructions, configurable product specifications, rubber granules, and related project support. Buyers can share their field application, preferred turf structure, technical requirements, estimated quantity, and destination market with our team to discuss a suitable product configuration and the relevant supporting documents.
      http://www.szgrass.com
      Jiangsu Shuangzhu Artificial Turf Co., Ltd.
