2025-12-18 at 6:42 pm #14688
Hexagonal bolts are often encountered in daily life, but because there are
many specifications of hexagonal bolts, it also causes some troubles for
consumers to choose hexagonal bolts. Today, let's take a look at what hexagonal
bolts are and what hexagonal bolt specifications are for your reference.Definition of hexagonal bolts
Hexagonal bolts are hexagonal head bolts (partial threads)-C grade and
hexagonal head bolts (full threads)-C grade, also known as hexagonal head bolts
(rough) rough hexagonal head bolts, black iron screws.Uses of hexagonal bolts
In conjunction with nuts, the threaded connection method is used to connect
two parts into a whole. The characteristic of this connection is that it is
detachable, that is, if the nut is unscrewed, the two parts can be separated.
The product grades are C, B, and A.Materials of hexagonal bolts
Steel, stainless steel, copper, aluminum, plastic, etc.
National standard codes of hexagonal bolts
GB5780, 5781, 5782, 5783, 5784, 5785, 5786-86
Specifications of hexagonal bolts
Thread specifications: M3, 4, 5, 6, 8, 10, 12, (14), 16, (18), 20, (22), 24,
(27), 30, (33), 36, (39), 42, (45), 48, (52), 56, (60), 64, not recommended in
brackets. Screw length: 20~500MMThe relevant information about hexagonal bolts is introduced here. I hope
this article is helpful to you. If you still have any questions, please leave a
message to the editor and we will answer you as soon as possible.http://www.xhruibang.com
Raybon Stainless Steel Standard Parts -
