2026-11-23 at 6:34 pm #18565
The usual MOQ for private label grill hot pot combo manufacturers is 150–300 pieces for a small retailer, 500 for a custom colour with your own retail box, and 1,000+ once the plate or housing changes — and none of those numbers come from the factory's appetite. They come from four suppliers one step upstream, each with its own minimum. This guide shows where those limits sit, what the fixed setup cost does to the price per unit at 100, 300, 500 and 1,000 pieces, and five levers that reliably bring the number down for first-time brand owners.
Published: November 2026 | By the Haoying Sales Team
1. Where Does the MOQ Actually Come From?
Every MOQ traces back to a supplier one step upstream, and the factory simply passes the constraint through. That is why the MOQ for private label grill hot pot combo manufacturers varies so much between otherwise identical quotations. On a combo cooker there are five real limits:
• Heating element — 500 pieces. Element suppliers quote from 500 units per rating; below that the factory either pays a $1.20–2.00 per unit surcharge or substitutes a different coil spec, which changes the wattage and forces a re-test.
• Thermostat and thermal fuse — 1,000 pieces per part number. Capillary thermostats are built to a specified tube length, so each new part number carries a 1,000-piece minimum. Using the factory's stocked part number removes this limit entirely, which is the cheapest way to lower an MOQ.
• Die-cast grill plate — 500 pieces per run. A 200-tonne press takes four to six hours to set up, so a 200-piece run carries the same setup cost as a 500-piece run and the factory prices it accordingly.
• Coating batch — 300–500 pieces. One powder batch covers roughly that many housings. A one-off RAL shade means flushing the line and mixing a dedicated batch, which adds $150–400 of waste the factory will not absorb on a small order.
• Printed carton and manual — 500–1,000 pieces. Offset printing needs plates and a minimum run; below that you go digital at $0.25–0.40 more per unit, or use a stock box with a printed label at about $0.05.
There is also a sixth limit that is not about quantity at all: a private-label UL or ETL listing costs $1,000–2,500 per model regardless of volume. At 200 pieces that is $5–12 per unit of pure certification, which is why low-volume sellers should first ask whether the factory's existing listing can be used in their marketplace.
✅ Bottom line: MOQ is the sum of five supplier minimums plus one per-model certificate — ask which one is driving your quote.
2. What Does Each Order Size Really Cost Per Unit?
Fixed setup cost is what makes small orders look expensive — roughly $1,250 on a typical private-label run once logo plates, packaging artwork, carton die-cuts, coating setup and line changeover are counted. Spread across the order, it changes the picture completely:
• 100 pieces: $12.50 per unit of setup on top of a $14–15 FOB price — the order costs more per unit than buying 500 and storing the difference.
• 300 pieces: $4.17 per unit. This is where most small retailers land, and where a stock colour plus a printed label keeps the total near $18–19 FOB-equivalent.
• 500 pieces: $2.50 per unit, and the point at which a custom colour and a full-colour retail box become worth ordering.
• 1,000 pieces: $1.25 per unit, plus the volume break on the unit price itself — usually another $1.50–3.00 per piece.
So a 100-piece order at $15 FOB often costs more per unit than a 500-piece order at $14. If 500 units is beyond your first budget, these five levers get you to 150–300 without paying the full setup:
• Take the stock colour and stock box. White or black housing with a printed label instead of a printed carton removes $600–900 of setup and is the single biggest MOQ reduction available.
• Mix models in one order. A 150 + 150 + 200 split across two combos and one grill fills the same production slot; most factories accept 100 pieces per model within a mixed order.
• Book the off-season window. February to April and July to August are the gaps between export peaks; factories filling idle line time will accept 30–40% lower MOQs than in September.
• Give a rolling forecast. A twelve-month schedule with quarterly releases frequently converts a 1,000-piece MOQ into four releases of 250, because the factory can buy components against the forecast instead of the order.
• Pay tooling separately. Moving the mould or plate cost out of the unit price removes the amortisation line and lets a small first order price like a large one.
Buyers searching for a wholesale 2 in 1 electric hot pot grill combo for resale price should ask one specific question before negotiating: does the factory run mixed-model containers? A wholesale 2 in 1 electric hot pot grill combo for resale order of 150 pieces is only economically viable when it shares a container position with two other models, because freight per unit at 150 pieces alone can add $6–9 that no discount recovers.
Put the lead time sample policy electric grill hot pot combo factory commitments into the proforma invoice rather than a chat message: sample lead time, production lead time, and what happens to the sample fee if you proceed. A factory that will not write those three lines down is telling you how the next delay will be handled. For reference, lead time sample policy electric grill hot pot combo factory norms in Yongkang are 7–10 days for a stock-model sample at $50–150 each, refunded or deducted at 500 pieces, and 25–35 days for production on a stock model.
✅ Bottom line: Buy 300 with a stock box instead of 100 custom — the setup you avoid pays for the extra units.
3. FAQ
Q: What MOQ should I ask for on a first order?
A: 150–300 pieces on a stock model with stock packaging, 500 if you need your own colour and printed box. Do not commit to 1,000 on a first order unless you have sell-through data — the volume saving rarely covers the working capital and the storage. When you compare MOQ for private label grill hot pot combo manufacturers, treat the figure as a range tied to packaging and part numbers rather than a fixed company policy.
Q: Can I combine models or colours in one order?
A: Usually yes, at around 100 pieces per model and 300 pieces per order. Mixing colours inside one model is harder than mixing models, because each colour is a separate coating batch — three colours at 100 pieces each will often cost more than three models at 100 pieces each.
Q: How long does a first order take from deposit to delivery?
A: 25–35 days for production on a stock model, plus 7–10 days for the sample and 3–5 days for artwork approval. Expect 45–60 days if a new plate or housing mould is involved, and add sea freight of 25–35 days to Europe or the US. Yongkang Haoying Electric Appliance Co., Ltd. quotes all four stages separately so the calendar is visible before you pay.
If you want to see what a stock-model base looks like before choosing a quantity, the Electric Grill with Hotpot F-042A is the platform most first orders start from, and the Haoying factory profile here lists the press, coating, and assembly capacity that sets those minimums.
Send Haoying your target quantity and market, and the team will come back with the MOQ that quantity can actually support, the setup cost behind it, and a mixed-model option if the number is too high — usually within one business day. Yongkang Haoying Electric Appliance Co., Ltd. has quoted these three lines the same way to 40+ repeat customers since 1995, which is why the MOQ conversation tends to end at a date rather than a discount.
http://www.hoyappl.com
Yongkang Haoying Electric Appliance Co., Ltd. -
