What’s wrong with the ESC fault light?
  • #8402
      The full name of ESC is Electronic Stability Controller (body electronic stability control system). It is an active safety technology that assists the driver to control the vehicle. It is also an anti-lock braking system (ABS) and a traction control system (TCS) for automobiles. Seeing the shadow of ABS and TCS functions, it can be said that it is the total integration of the current vehicle safety electronic equipment.
      ESC lights up how to solve?
      ESC is mainly composed of sensors, actuators and electronic control unit (ECU) It consists of three parts, any part will fail ESC When the fault light is on, we are facing it esc When the warning light is on, try restarting the engine, then Press the vehicle ESC off button and finally restart to see if the warning light is caused by a false fault.
      ESC fault indicator light is a more complex fault problem, generally caused by the alarm caused by the software system, it may also be due to sensor fault or line short circuit, false alarm is not excluded, detection is more troublesome, need to use a special fault diagnosis instrument to troubleshoot Excluded and confirmed, so it is best to send it to the 4S repair shop for the first time.
      Haike
      jiangsheng@hakrc.com
