When Architectural Aluminum Becomes Part of the Building’s Identity
  • #17293
      Modern architecture increasingly treats ceilings, interior walls, and façades as connected parts of one architectural language. Instead of using aluminum only as a conventional exterior cladding material, architects can use customized aluminum forms to shape visual rhythm, circulation, lighting integration, and the overall identity of a space.
      The WILLSTRONG® project concept provides a useful perspective on this transition. A major public building such as the China National Convention Center Phase II in Beijing demonstrates how architectural elements above and around people can contribute to the experience of a large interior environment. At the same time, completed WILLSTRONG® applications show how customized aluminum can move between exterior façades and interior architectural surfaces.
      From Functional Ceiling to Architectural Element
      In a large convention center, a ceiling is not simply a surface covering the structure above. Lighting, ventilation, fire protection, signage, access points, and other building services all have to be accommodated while preserving the intended visual character of the space.
      This creates a challenge for architects and manufacturers: technical components need to be integrated without disrupting the architectural concept.
      Customized aluminum can provide a practical way to approach this problem. Panels, linear elements, openings, lighting positions, and service interfaces can be coordinated around a defined geometry, allowing the ceiling to become part of the overall spatial composition.
      The China National Convention Center Phase II in Beijing is a useful reference in this context. The project extends the existing convention center and incorporates a large-scale architectural concept inspired by the traditional Chinese flying-eaves form. Its exterior geometry, irregular openings, and flowing visual language create a sense of movement.
      That design thinking can also be reflected in the interior. Rather than viewing the ceiling as an isolated technical layer, architectural aluminum can help continue the building's visual language into public spaces.
      For architects, the advantage is not simply that aluminum is lightweight or workable. Its greater value comes from the ability to process the material into forms that correspond with the design intent.
      Turning Architectural Concepts into Real Components
      A complex architectural drawing is only the beginning. The real challenge is turning unusual shapes, curves, angles, and repeated patterns into components that can be manufactured consistently and installed accurately.
      This is where fabrication capability becomes especially important.
      Customized architectural aluminum may involve cutting, bending, forming, CNC machining, edge processing, welding, and surface treatment. Each stage can affect the dimensional accuracy and final appearance of the finished component.
      When hundreds or thousands of components are combined into one architectural surface, even small dimensional variations can influence alignment and visual continuity.
      WILLSTRONG® Architectural Art Aluminium is developed around this type of customized architectural application. The product is manufactured from solid aluminum alloy and can undergo precision machining and surface treatment to create different forms and finishes.
      The manufacturing process can be considered in several stages:
      Material Processing
      The aluminum material is prepared according to the dimensions and structural requirements of the project. Depending on the design, different cutting, forming, bending, and edge-processing operations may be required.
      Precision Fabrication
      CNC-based machining can translate complex design information into accurately manufactured architectural components. This is particularly useful for curved, irregular, perforated, or highly detailed elements.
      Surface Treatment
      The final surface treatment contributes to the appearance and consistency of the finished aluminum. It can be selected according to the architectural concept and project requirements.
      This connection between design, engineering, and manufacturing is one of the most important considerations when selecting an architectural aluminum solution.
      A WILLSTRONG® Project Reference: Xi'an Maco Commercial Center
      A practical example of customized architectural aluminum can be seen at the Xi'an Maco Commercial Center, where WILLSTRONG® Architectural Art Aluminium was used for an exterior wall application.
      Completed between 2018 and 2019, the project demonstrates how aluminum can move beyond the appearance of standardized flat panels. Customized forms can introduce additional depth, geometry, and visual variation to a commercial building.
      The exterior needed to establish a recognizable contemporary identity while remaining suitable for practical building use. Solid aluminum alloy combined with precision machining and surface treatment provided a material platform for achieving customized architectural details.
      This type of application is particularly relevant to commercial architecture. A building's exterior often serves as one of its strongest visual identifiers, and customized metal elements can help distinguish a project without relying exclusively on conventional rectangular cladding.
      The lesson is not that every commercial façade needs complex geometry. Rather, the project illustrates the value of having a material system capable of responding when the architectural concept requires something beyond standard panels.
      Precision Machining Expands Design Possibilities
      One of the most significant differences between conventional metal cladding and architectural art aluminum is the level of customization that can be achieved.
      Standard panels can efficiently address many façade applications, but certain architectural concepts require specific profiles, angles, curves, or surface details.
      Precision machining provides greater control over these elements. It allows a solid aluminum component to be processed according to the dimensional information required by the architectural design.
      For a commercial project, this can help transform an ordinary wall into a more recognizable architectural surface. For an interior application, the same approach can be used to create a refined wall, ceiling, screen, or decorative element.
      The important point is that design freedom depends on manufacturing capability. A visually ambitious concept still needs to be translated into repeatable components with controlled dimensions and consistent finishes.
      Surface Treatment Is Part of the Design
      The shape of an aluminum component is only one aspect of its architectural performance. Surface appearance also influences how the material interacts with light and surrounding finishes.
      A carefully selected surface treatment can help maintain visual consistency across customized components while supporting the intended architectural expression.
      In projects such as Xi'an Maco Commercial Center, the combination of customized geometry, refined surface treatment, and solid aluminum construction contributes to the overall appearance of the building.
      For exterior applications, material selection and finishing also need to be considered in relation to environmental exposure and long-term appearance. For interiors, surface consistency and the relationship between aluminum and lighting can become more important.
      This is why architectural aluminum should be evaluated as a complete material-and-processing solution rather than simply as a sheet or panel.
      From Façade Applications to Interior Architecture
      Customized aluminum is not limited to exterior walls. The same manufacturing principles can be adapted to interior architectural applications.
      At Vanke Jade State Guest in Xi'an, WILLSTRONG® Architectural Art Aluminium was used for an interior wall application completed in 2020. Here, the focus shifted from exterior identity toward the creation of a refined interior surface.
      The Yanji & Xi'an Flagship Store, completed in 2020 and known as “The Most Beautiful Internet Celebrity Bookstore,” provides another example of customized architectural aluminum used for an exterior wall.
      These different projects illustrate an important characteristic of architectural aluminum: the same basic material technology can serve different architectural roles depending on geometry, processing, finish, and installation requirements.
      A single material approach can therefore support exterior façades, interior walls, ceilings, decorative features, and other customized architectural elements.
      What Customized Aluminum Adds to Architectural Projects
      The value of architectural aluminum becomes clearer when several requirements need to be addressed simultaneously.
      For a ceiling, aluminum can be shaped into curved, linear, or layered forms while accommodating lighting and building services.
      For an interior wall, customized panels can reinforce the atmosphere and visual identity of a space.
      For a façade, specially processed aluminum can create distinctive profiles and architectural details that are difficult to achieve with standard flat cladding.
      In all three situations, material selection is only one part of the solution. Engineering coordination, fabrication accuracy, surface treatment, installation planning, and quality control also influence the final result.
      This is why architects, façade consultants, contractors, and developers often need to evaluate the manufacturer's capabilities at the same time as they evaluate the material itself.
      Why Manufacturing Capability Matters
      A successful customized aluminum project depends on the transition from concept to production.
      The manufacturer needs to understand architectural drawings, dimensional requirements, assembly relationships, finishing expectations, and installation conditions. At the production stage, machining accuracy and process consistency become critical.
      According to its official information, WILLSTRONG® has more than 30 years of experience since its establishment in 1995, with more than 30 certifications worldwide, more than 10 technology patents, over 100,000 successful projects and applications, and customers across more than 80 countries and regions.
      Its current architectural aluminum offering uses solid aluminum alloy with precision machining and surface treatment, while its broader manufacturing capabilities include CNC-based deep processing.
      For international project teams, this type of manufacturing background can be particularly relevant when a project requires customized components rather than standard catalog panels.
      A Broader Role for Architectural Aluminum
      The growing use of customized aluminum in modern buildings reflects a wider change in architectural thinking.
      Materials are increasingly expected to do more than provide weather protection or basic enclosure. They may contribute to spatial identity, visual continuity, lighting integration, interior atmosphere, and the recognition of a landmark building.
      The China National Convention Center Phase II provides an interesting reference for understanding this trend. Its architectural concept demonstrates how a building can translate traditional forms into a contemporary language, while its large public interiors show why architectural details need to work together rather than independently.
      WILLSTRONG®'s own project applications, including Xi'an Maco Commercial Center and Vanke Jade State Guest, provide practical examples of how customized aluminum can be adapted to different architectural environments.
      The underlying principle is straightforward: when architecture requires greater freedom of form, the material and manufacturing process need to provide enough flexibility to support that freedom.
      Looking Ahead with WILLSTRONG®
      Established in 1995, WILLSTRONG® has developed its business around façade products and architectural material solutions. Its portfolio includes aluminum composite panels, fire-resistant composite materials, aluminum honeycomb systems, and Architectural Art Aluminium.
      The company's philosophy, “Crafting with Quality, Making for Excellence,” reflects an approach that goes beyond the appearance of the finished material. Material selection, manufacturing precision, surface treatment, engineering coordination, and project support all contribute to the final architectural result.
      As architectural design becomes more complex, the relationship between architects and material manufacturers is likely to become increasingly important. A concept can only become a completed building when it can be engineered, fabricated, transported, and installed with sufficient consistency.
      For this reason, customized architectural aluminum is not simply another façade material. It can serve as a bridge between creative design and practical construction.
      From exterior walls to interior surfaces, from commercial buildings to large public venues, the potential of aluminum continues to expand. When supported by appropriate machining, finishing, and project coordination, it can become an active part of architectural expression rather than merely a background building material.
      For architects, designers, contractors, and developers exploring customized metal solutions, WILLSTRONG® Architectural Art Aluminium offers an approach centered on solid aluminum alloy, precision fabrication, surface treatment, and flexible architectural forms.
      http://www.willstrong360.com
      WILLSTRONG®
