When Should Industrial Equipment Use Plastic Components Instead of Metal?
  • #18062
      Metal is often the default choice when engineers design industrial equipment. It is familiar, widely available, and suitable for components that must withstand substantial loads. Yet metal is not always the most practical option. In applications involving sliding contact, frequent movement, moisture, electrical isolation, or complex part geometries, an engineered plastic component may offer a better fit.
      The decision is rarely as simple as comparing the price of a plastic part with that of a metal equivalent. Engineers need to consider how the component functions within the complete assembly, how it will be manufactured, and what it will cost to operate and maintain over time.
      Start With the Function, Not the Material
      A useful starting point is to define what the component actually does. A bracket supporting a heavy load has different requirements from a guide that moves a workpiece along a production line. Treating both as general-purpose structural parts can lead to unnecessary material costs or design compromises.
      Plastic components are worth considering when the primary function involves:
      • Guiding, spacing, positioning, or supporting moving parts
      • Reducing friction between contacting surfaces
      • Electrically isolating adjacent components
      • Providing corrosion resistance in a particular operating environment
      • Producing complex shapes without extensive secondary operations
      Metal may remain the stronger candidate where high stiffness, substantial impact resistance, elevated operating temperatures, or concentrated mechanical loads dominate the design requirements.
      Some assemblies also benefit from a mixed-material approach. A metal frame can provide the main structural support, while plastic guides, bushings, spacers, and covers handle contact, movement, or insulation. This avoids forcing one material to meet every requirement.
      Four Situations Where Plastic Components Can Make Sense
      1. Moving Parts Need Controlled Friction
      Sliding guides, bushings, wear strips, rollers, and small gears often operate through repeated contact. In these applications, friction and wear can affect positioning accuracy, operating noise, maintenance intervals, and the service life of the surrounding components.
      Certain engineering plastics are suitable for these duties because their friction and wear characteristics can reduce the need for lubrication in some designs. However, performance depends on the polymer grade, mating surface, contact pressure, speed, temperature, and operating environment.
      A plastic bushing, for example, may work well in a mechanism with moderate loads and regular movement. The same material could deform excessively if the load is concentrated over a small contact area or if the assembly runs hot.
      Before specifying a material, engineers should establish the expected load, movement pattern, operating temperature, and acceptable wear. They should also consider whether lubricant is permitted and whether debris generated through wear could affect nearby equipment.
      2. The Component Must Isolate Electricity
      Electrical assemblies often contain parts that need to maintain separation between conductive elements. Depending on the design, these may include spacers, support blocks, terminal barriers, mounting plates, and custom insulating components.
      Engineering plastics and laminated insulation materials can serve different roles in these applications. The right choice depends on more than whether a material is electrically insulating. Voltage, temperature, mechanical loading, moisture exposure, creepage and clearance requirements, and the relevant electrical standards all influence the specification.
      For example, a machined plastic support used to position a component may need to retain its shape under clamping pressure as well as provide electrical isolation. A thin barrier inside electrical equipment faces a different set of requirements.
      Engineers should evaluate the material in the context of the finished component and the complete electrical assembly. A general material description alone cannot establish suitability for a particular voltage or operating condition.
      3. Corrosion or Environmental Exposure Creates Maintenance Problems
      Metal parts can require coatings, surface treatments, or periodic replacement when exposed to moisture or certain chemicals. In selected environments, a compatible engineering plastic may simplify the design by eliminating the need for some protective treatments.
      This can be relevant to fluid-handling equipment, packaging machinery, laboratory equipment, and production systems that undergo frequent cleaning.
      The important word is compatible. No plastic should be assumed to resist every chemical or cleaning agent. Concentration, exposure duration, temperature, mechanical stress, and the specific polymer formulation can all influence material performance.
      A component that performs well in room-temperature water may behave differently when exposed to a concentrated cleaning solution at elevated temperature. Chemical compatibility should therefore be checked against the actual operating conditions rather than inferred from a broad material category.
      4. The Part Has a Complex Shape or Must Be Customized
      Industrial equipment frequently uses components that are not available in standard dimensions. A machine may require a stepped spacer, a shaped support, a special mounting block, or a guide with several holes and slots.
      Machining plastic stock can be a practical way to produce these parts, particularly when the design is still evolving or production volumes do not justify dedicated tooling. It also allows dimensions and interfaces to be adjusted for a specific machine.
      For instance, POM sheets and rods for machined plastic components can be considered for applications such as positioning parts, bushings, guides, and other components where the material's properties suit the service conditions.
      The choice still depends on the part's geometry and function. Thin walls, long unsupported sections, tight fits, and uneven material removal can complicate machining. A material that is easy to cut does not automatically produce a dimensionally stable finished part.
      What Engineers Should Check Before Replacing Metal
      Replacing a metal component with plastic changes more than its material cost. The new part may have different stiffness, thermal expansion, load-bearing behavior, and wear characteristics. A successful substitution begins with a review of the conditions that the original component must withstand.
      Design factor Questions to resolve
      Mechanical loading What forces act on the part, and are they static, repeated, or impact-related?
      Temperature What are the normal operating temperature and any short-term temperature peaks?
      Movement and wear Does the part slide, rotate, or repeatedly contact another surface?
      Dimensional requirements Which dimensions control alignment, clearance, or assembly fit?
      Environment Will the part encounter moisture, oils, solvents, cleaning agents, or outdoor exposure?
      Electrical function Is insulation required, and what standards or design limits apply?
      Production volume Is the part a prototype, a small batch, or a component for ongoing production?
      These questions help narrow the options before detailed design work begins. They also reduce the risk of selecting a material based on one attractive property while overlooking a more important limitation.
      Manufacturing Method Can Change the Decision
      A material must be suitable not only for the application but also for the intended production method. A simple spacer may be inexpensive to machine from stock, while a high-volume component with a repeatable molded geometry may justify a different manufacturing route.
      CNC machining is useful when parts require precise features, custom dimensions, or design changes without dedicated molds. However, the final result depends on tool selection, machining strategy, workholding, part geometry, and dimensional inspection.
      Plastic parts can also behave differently from metal during machining. Heat generated during cutting, internal stresses, and the material's expansion characteristics may affect dimensions. For parts with tight tolerances, manufacturers should consider how measurements will relate to the component's actual operating temperature and assembly conditions.
      Engineers should identify critical dimensions rather than applying unnecessarily tight tolerances to every feature. This makes inspection more focused and can help avoid manufacturing cost that provides no functional benefit.
      For a closer look at the relationship between component design and production, see this discussion of precision machining for electrical insulation components. Although electrical insulation parts have their own requirements, the broader principle also applies to custom-machined engineering plastics: material selection and part design need to be considered together.
      Compare Total Cost, Not Just Purchase Price
      A lower unit price does not necessarily translate into a lower overall cost. The more useful comparison includes manufacturing, assembly, maintenance, downtime, and replacement.
      A plastic component may reduce weight or simplify an assembly, but it may also require a larger cross-section to achieve adequate stiffness. A metal part may have a higher initial machining cost but offer a longer service life under heavy loads. Neither material is automatically more economical.
      For procurement teams, the comparison should account for:
      • Manufacturing cost: Material usage, machining time, tooling, finishing, and inspection.
      • Assembly cost: Whether the part needs inserts, additional fasteners, or design changes.
      • Maintenance requirements: Lubrication, wear checks, cleaning, and replacement frequency.
      • Failure consequences: The effect of deformation or wear on the surrounding equipment.
      • Order quantity: Whether the selected manufacturing process remains economical as demand changes.
      Where the consequences of failure are significant, prototype testing or a controlled trial can provide useful evidence before a full production change is approved.
      A Better Material Decision Begins With the Application
      Plastic should not be treated as a universal replacement for metal, nor should metal remain the default simply because it has traditionally been used. The better choice is the one that meets the component's mechanical, environmental, electrical, dimensional, and manufacturing requirements at an acceptable total cost.
      For engineers, that means defining the operating conditions before choosing a material. For buyers, it means giving manufacturers enough information to assess the intended function rather than requesting a quote based on dimensions alone. When these details are clear, it becomes easier to compare material options, evaluate manufacturing routes, and develop components that work as intended in the finished equipment.
      http://www.yiyijueyuan1.com
      yiyi
