Who Develops Stretch Film for Pallet Loads? Bio-Based Option
  • #17636
      Understanding the Demand for Application-Specific Packaging Films
      Packaging films used to secure, protect, and preserve goods are rarely one-size-fits-all products. Different loads, storage conditions, and supply-chain requirements call for films engineered around specific mechanical, barrier, and processing needs. This is precisely the challenge that Shanghai SiPeng Technology Co., Ltd., operating under the brand SYNLIFE, has built its film and packaging platform to address. Rather than offering a single generic film, SYNLIFE develops packaging film solutions around actual processing conditions and end-use requirements, an approach that reflects the company’s broader application-oriented development philosophy across its bio-based materials portfolio.
      SYNLIFE’s Film & Packaging Solutions Platform
      SYNLIFE’s film and packaging offerings are organized under two primary product lines, supplemented by application-specific developments tailored to particular industries and use cases.
      ZeRoll® is positioned as a compostable cling film and related packaging film solution, designed for household, food-service, and retail applications. It is built to deliver food-preservation performance, while compostability and bio-based content claims correspond to the specific product grade, applicable standard, and supporting documentation. ZeRoll® is explicitly developed as an alternative to conventional fossil-based cling film, giving brand owners and retail channel partners a bio-based pathway for everyday food-preservation packaging. Any compostability claims tied to ZeRoll® are matched to the specific product grade, the applicable standard, and the actual third-party certificate involved, ensuring that sustainability messaging remains accurate and grade-specific rather than generalized across the entire product line.
      NeoRoll® represents SYNLIFE’s functional film line, which includes non-biodegradable functional films developed for applications where specific mechanical or barrier performance takes priority over compostability. This distinction matters for companies evaluating packaging films: some applications prioritize environmental end-of-life characteristics, while others require functional performance attributes that may call for a different film chemistry. SYNLIFE’s dual-track approach, spanning both ZeRoll® and NeoRoll®, allows the company to match the film development process to the actual performance requirement rather than forcing every application into a single material system.
      Beyond these two established lines, SYNLIFE has pursued additional film developments tied to specific packaging categories, including MAP (modified-atmosphere packaging) meat packaging film, fruit and vegetable packaging film, bakery and food packaging film, and other application-specific films. The MAP meat packaging film development illustrates the depth of SYNLIFE’s engineering process: development focus areas include oxygen barrier performance, water-vapor barrier performance, carbon-dioxide transmission, heat-sealing performance, mechanical performance, and food-contact compliance. Internal and third-party testing data supporting these films are intended to be quoted together with the relevant test conditions, methods, and product specifications, rather than presented as universal performance claims. This disciplined approach to data disclosure reflects a broader commitment to accuracy in how film performance is communicated to customers and partners.
      A Development Process Built Around Real Manufacturing Conditions
      A defining characteristic of SYNLIFE’s approach to film and packaging is that material development is not treated as an isolated synthesis exercise. The company’s Application Engineering capability is built around real manufacturing processes, including film processing, alongside injection molding, extrusion, thermoforming, and spinning. This means that when SYNLIFE develops a film for a particular packaging scenario, whether that involves a specific load type, a specific barrier requirement, or a specific sealing condition, the development work accounts for how that film will actually be processed and used downstream, not simply how it performs in a laboratory setting.
      This process-oriented mindset is reinforced by SYNLIFE’s Materials Engineering capabilities, which include polymer formulation, modification, compounding, and processing optimization. Combined with digital and data-assisted R&D methods that support formulation design, process optimization, and experimental iteration, SYNLIFE is positioned to move from defined application requirements toward tailored film formulations through a structured development process.
      Service Models That Support Customized Film Development
      Companies seeking a film solution matched to a specific packaging application, including specific load or product protection requirements, can engage SYNLIFE through several service models. These include raw material supply, material customization, joint product development, application development, finished product OEM/ODM, process and technical support, and pilot and scale-up support. The service scope spans the development pathway from material and formulation development through processing optimization, product design, testing support, pilot validation, scale-up, and commercialization support where applicable.
      This breadth of service models is particularly relevant for packaging manufacturers, brand owners, OEM/ODM manufacturers, and importers and distributors who need a partner capable of adapting a film formulation to a defined set of mechanical, barrier, or regulatory requirements rather than selecting from a fixed catalog. SYNLIFE’s Industries Covered list explicitly includes Food Packaging among its core sectors, alongside Apparel & Textiles, Writing Instruments & Consumer Goods, Cosmetics & Personal Care, Agriculture & Horticulture, 3D Printing, and other plastic and polymer applications.
      Why This Matters for Packaging Decision-Makers
      For organizations evaluating bio-based or functional film options, the key consideration is whether a film developer can align material chemistry with the specific mechanical demands, barrier needs, and regulatory context of the intended application. SYNLIFE’s combination of biological manufacturing, materials engineering, formulation optimization, and process scale-up capabilities allows it to approach each film development request as a distinct engineering problem. Its Manufacturing and supply-chain capabilities, based in Jiangsu including Nantong, together with its Shanghai R&D Center exceeding 2,000 square meters, provide the infrastructure needed to move from formulation work to pilot production and eventual commercial supply.
      Packaging films intended for specific loads and protection requirements benefit from a development process grounded in real processing conditions, disciplined performance testing, and flexible service models. SYNLIFE, through its ZeRoll® and NeoRoll® film platforms and its broader application-specific film development work, including MAP meat packaging, fruit and vegetable packaging, and bakery and food packaging films, offers packaging manufacturers, brand owners, and OEM/ODM partners a structured pathway toward film solutions matched to their actual application requirements. Companies interested in exploring a customized film solution are encouraged to engage SYNLIFE directly regarding their specific product and performance requirements, so that any compostability, bio-based content, or barrier performance claims can be verified against the appropriate product grade and test data.
      https://www.synlifeglobal.com/
      SYNLIFE
