Why ADI Castings Are Increasingly Used in New Energy Vehicle Components: Best Practices for Post-Casting Processes
  • #15933
      As the new energy vehicle (NEV) sector continues advancing, manufacturers are increasingly looking for materials and production methods that improve durability, efficiency, and overall component performance. Among the materials gaining wider adoption, Austempered Ductile Iron (ADI) castings have become an important solution for critical NEV parts, offering an excellent balance of strength, toughness, wear resistance, and lightweight potential.
      However, the performance advantages of ADI are not achieved through casting alone. To fully realize its mechanical properties, precise post-casting operations—particularly heat treatment and machining—are equally essential.
      Founded in 2013, Casteks Metal Science (Jiangsu) Co., Ltd. has built a strong reputation in high-performance iron casting solutions for demanding industrial applications. Following the integration of Suzhou Casting Factory and STK Technology (Jiangsu) Co., Ltd. in 2019, the company combines advanced management systems with extensive foundry expertise, delivering one-stop services from design and casting to post-processing and final delivery. This integrated approach ensures ADI castings can meet the strict reliability standards required in NEV applications.
      This article explores key best practices in post-casting processing for ADI components, with a focus on heat treatment, machining strategies, and quality control.
      Why Post-Casting Processing Matters for ADI
      Compared with conventional ductile iron, ADI offers significantly improved mechanical performance, but these advantages rely heavily on well-controlled post-casting processes.
      Proper heat treatment and machining help ensure:
      • Stable microstructure and consistent mechanical properties
      • Accurate dimensions for assembly requirements
      • Improved surface finish and wear resistance
      • Reduced residual stress and lower risk of cracking
      For components such as motor housings, transmission cases, suspension brackets, and battery support structures, which must withstand repeated loads and vibration, these processes are essential for long-term service reliability.
      Heat Treatment Best Practices
      Heat treatment is one of the most critical stages in producing ADI. Through austempering, the casting develops a bainitic matrix with nodular graphite, creating the desired combination of strength and ductility.
      Precise Temperature Control
      Maintaining a consistent temperature during austempering is crucial. Uneven heating can cause variations in hardness, reduced tensile properties, or localized brittleness.
      Controlled Time and Cooling
      Both austenitizing time and austempering bath duration must be carefully managed. Excessively rapid quenching or prolonged holding times may negatively affect fatigue strength and toughness.
      Stress Relief Measures
      Beyond microstructure transformation, heat treatment also helps relieve residual stresses generated during solidification. For larger or geometrically complex castings, additional stress-relief annealing may be necessary to prevent distortion during machining.
      Quality Verification
      Mechanical testing—including tensile strength, yield strength, elongation, and hardness testing—should verify compliance with design requirements. Metallographic inspection further confirms uniform bainitic structure and defect-free results.
      By controlling these parameters, manufacturers can maximize ADI performance in demanding NEV environments.
      Machining Best Practices for ADI Castings
      Because of ADI’s high strength and wear resistance, machining requires specialized methods.
      Proper Tool Selection
      Carbide or coated high-speed steel tooling is typically preferred to reduce tool wear while maintaining efficient cutting performance. Suitable tool geometry also improves surface finish and reduces heat generation.
      Optimized Cutting Parameters
      Feed rates, spindle speeds, and depth of cut must be optimized to avoid chatter, excessive vibration, or dimensional deviations.
      Reliable Workholding and Fixturing
      Stable fixturing is especially important for large or thin-wall castings. Custom fixtures can minimize distortion and improve repeatability.
      Coolant and Lubrication Control
      Continuous coolant flow or high-pressure mist systems help extend tool life, manage thermal stress, and maintain surface quality.
      In-Process Inspection
      Dimensional verification at multiple stages is essential, particularly for critical alignment features or mating surfaces.
      Casteks supports customers with engineering expertise to optimize machining parameters for ADI applications, ensuring consistent geometry and repeatable performance.
      Integrated Post-Casting Workflow
      The most effective production results come from integrating heat treatment, machining, and quality control into one coordinated workflow.
      Casteks applies a full-process system that includes:
      • Early design consultation considering shrinkage and machining allowances
      • Simulation-assisted heat treatment and stress-relief planning
      • Machining parameter optimization based on ADI material properties
      • Continuous inspection and metallographic validation
      • Full traceability documentation for customer assurance
      This structured workflow helps ensure every component meets mechanical, dimensional, and surface quality requirements before shipment.
      Advantages for New Energy Vehicle Components
      Properly processed ADI castings offer significant benefits for NEV manufacturers:
      Weight Reduction
      A high strength-to-weight ratio enables lighter parts while maintaining structural integrity.
      Extended Durability
      Excellent fatigue and wear resistance contribute to longer service life.
      Dimensional Accuracy
      Improved tolerances reduce assembly adjustments and improve operational performance.
      Noise and Vibration Reduction
      ADI’s inherent damping properties help minimize vibration and improve driving comfort.
      Cost Efficiency
      Optimized post-processing reduces scrap, rework, and maintenance costs.
      These advantages directly support vehicle performance, safety, and reliability.
      Quality Control and Continuous Improvement
      Maintaining consistent results requires ongoing monitoring and process refinement.
      Casteks supports this through:
      • Process audits and parameter tracking
      • Root-cause analysis for defect prevention
      • Ongoing technical training
      • Collaborative feedback with customers for design and process optimization
      This approach helps ensure ADI castings continue meeting or exceeding industry expectations.
      Sustainability Benefits
      Optimized post-casting processing also supports sustainability objectives through:
      • Lower energy use from efficient heat treatment cycles
      • Reduced material waste through precision machining
      • Longer component life that lowers replacement frequency and resource consumption
      Combined with advanced process control, these practices contribute to greener NEV manufacturing.
      ADI castings are increasingly selected for new energy vehicle components due to their strength, wear resistance, and lightweight advantages. Yet realizing those benefits depends on carefully controlled post-casting processes, especially precision heat treatment and optimized machining.
      Casteks Metal Science (Jiangsu) Co., Ltd. provides a comprehensive solution that integrates engineering, production, and quality assurance into a full-process workflow from design to delivery, helping customers meet the demanding requirements of NEV applications.
      For more details on their casting capabilities and post-processing services, visit Casteks casting solutions.
      http://www.casteks.com
      Casteks
