Why are your Coriolis mass flow meter readings unstable? Analysis of causes and solutions
  • #14246
      In the field of fluid measurement, Coriolis mass flow meters are widely used in industries such as petrochemicals, food and beverage, pharmaceuticals, and energy due to their high accuracy and ability to directly measure mass flow rate and density. However, many users find that instrument readings occasionally fluctuate, waver, or become unstable during actual use, leading to measurement data deviations and even affecting the control accuracy of the entire system.
      This article will delve into the main causes of unstable Coriolis mass flow meter readings and provide feasible troubleshooting and solution strategies to help users quickly locate problems and improve measurement reliability.
      1. Brief Description of the Working Principle of Coriolis Mass Flow Meters
      Before discussing the causes of instability, it is essential to understand its basic working principle.
      A Coriolis mass flow meter mainly consists of a vibrating measuring tube, a drive coil, a vibration sensor, and a signal processing unit. When fluid passes through the vibrating tube, the drive coil causes the measuring tube to vibrate at a fixed frequency. The fluid flow generates a Coriolis force within the vibrating tube, which creates a phase difference in the pipe.
      The instrument calculates the mass flow rate by detecting the phase difference between the vibration signals at both ends. Meanwhile, changes in vibration frequency can also reflect fluid density, thus enabling dual measurement of mass flow rate and density.
      Therefore, Coriolis mass flow meters are extremely sensitive to vibration environments. Any factor affecting pipe vibration or fluid flow pattern can lead to signal instability, resulting in fluctuations in flow readings.
      2. Common Causes of Unstable Readings
      2.1 Pipe Vibration Interference
      In actual installation environments, external mechanical vibration is one of the primary factors causing fluctuations in Coriolis mass flow meter readings.
      For example:
      Mechanical vibrations from equipment such as pumps, compressors, and valves are transmitted through pipes;
      Interference is generated by mechanical systems with resonant frequencies close to the flow meter;
      The flow meter is installed on a non-rigid support structure, such as a suspension or thin-walled bracket.
      These all alter the natural vibration state of the measuring tube, causing errors in signal acquisition.
      Solutions:
      Avoid installing the flow meter near vibration sources;
      Use flexible connectors or vibration-damping brackets;
      If necessary, external interference can be reduced by adjusting the direction of the measuring tube or installing dampers.
      2.2 Presence of Air Bubbles or Gas-Liquid Mixtures in the Fluid
      Coriolis mass flow meters are suitable for single-phase fluids. When the medium contains air bubbles, vapor, or gas-liquid mixtures, the fluid density fluctuates continuously, causing signal instability.
      Especially in liquid fluid measurements, when air bubbles pass through the measuring tube, the change in fluid density instantaneously alters the vibration frequency, leading to misjudgments of flow rates.
      Solutions:
      Ensure no residual gas in the pipeline before installation;
      For liquid media, add a degassing device or gas-liquid separator;
      For easily vaporized fluids, avoid excessive pressure drop and maintain sufficient system pressure.
      2.3 Unstable Fluid Flow Pattern Although Coriolis mass flow meters do not have high requirements for straight pipe sections, the fluid flow pattern still affects its measurement stability.
      Typical situations include:
      Valves upstream are not fully open or are partially blocked;
      Serious changes in flow velocity lead to increased turbulence;
      Sudden changes in upstream pipe diameter or excessively short bends result in uneven flow patterns before the fluid enters the measuring tube.
      These problems cause vibration signal fluctuations, manifesting as output value jitter.
      Solutions:
      Maintain appropriate stable flow ranges (generally 5D-10D) before and after the flow meter;
      Use rectifiers or flow stabilization devices;
      Ensure fluid velocity remains within the recommended range.
      2.4 Electrical Interference and Poor Grounding
      Coriolis flow meter sensor output signals are generally weak and easily affected by electromagnetic interference (EMI) or electrostatic noise.
      For example:
      Nearby high-power frequency converters, motors, welding machines, etc.;
      The grounding wire is not separately laid or the grounding resistance is too high;
      The shielding layer wiring method is not standardized.
      These problems can all cause abnormal readings by the signal processing unit, resulting in display fluctuations.
      Solutions:
      Ensure single-point grounding of the instrument and control system, and use independent grounding wires;
      Use double-shielded cables for signal lines, and avoid parallel wiring with power lines;
      Appropriately add EMI filters or isolate the transmitter module.
      2.5 Improper Installation
      The installation position and orientation also significantly affect measurement stability. Incorrect installation methods can cause air bubble retention or sediment accumulation, affecting signal output.
      Common errors include: Incorrect vertical pipe installation orientation (air bubbles are difficult to expel when liquid flows from top to bottom); The flow meter is located at the pump suction end, causing negative pressure and air intake; Bending or torsional stress exists at the installation site, affecting the vibration of the measuring tube.
      Solutions: Prioritize horizontal installation and operation where the pipe is completely filled with fluid; Avoid installation at the pump inlet or at high points; For large-diameter or long-distance pipelines, increase support points to reduce mechanical stress.
      2.6 Temperature and Pressure Fluctuations
      Although Coriolis flow meters can automatically compensate for temperature and density changes, drastic temperature or pressure fluctuations can still cause temporary instability.
      For example:
      Fluid temperature changes cause expansion of the measuring tube metal; Sudden pressure changes cause fluctuations in medium density.
      Solutions: Add pressure stabilization devices and temperature control to the system; Avoid frequent fluid switching or changes in temperature conditions; Select high-end models with stronger temperature compensation performance.
      2.7 Electronic Module or Sensor Failure
      If the above external factors have been eliminated and unstable readings still exist, the problem may be due to a fault in the instrument's internal electronic module, drive circuit, or sensor. Symptoms include: Signal drift and irregular jumps; continued fluctuations even after calibration; and periodic interruptions in the output signal.
      Solutions: Check if the sensor cable is aging or damp; perform a self-test using the manufacturer's diagnostic software; if hardware damage is confirmed, send it for repair or replacement promptly.
      3. Systematic Troubleshooting and Maintenance Recommendations
      To ensure the long-term stable operation of the Coriolis mass flow meter, the following system maintenance plan can be referenced:
      Establish benchmark records: After installation and commissioning, record standard flow, density, and temperature values for future comparison.
      Regularly clean the measuring tube: Especially in high-viscosity or crystalline media, keeping the flow channel clean can significantly reduce fluctuations.
      Regularly check grounding and cable connections: Prevent oxidation or loosening that could cause signal abnormalities.
      Environmental monitoring: Keep the installation area free from strong vibrations and electromagnetic interference.
      Regular calibration: It is recommended to perform factory standard calibration or on-site calibration every 12 months.
      Through systematic maintenance, not only can the probability of measurement instability be reduced, but the instrument's lifespan can also be extended, improving the overall system reliability. In modern industrial automation, accurate flow measurement is the cornerstone of process control. Understanding and properly addressing the issue of unstable Coriolis flow meter readings can not only improve the stable operation of production lines but also reduce maintenance costs, improve energy efficiency, and bring greater economic and management benefits to enterprises.
      Accura Instrument, as a professional manufacturer and supplier of Coriolis mass flow meters, is committed to providing global customers with high-precision and high-stability fluid measurement solutions. The company possesses advanced production equipment and a rigorous quality management system, and its products are widely used in industries such as chemical, petroleum, food, pharmaceutical, and energy. Whether for standard or customized measurement needs, Accura Instrument provides reliable instruments and comprehensive technical support to help customers achieve more accurate and efficient flow control.
      http://www.accurainstrument.com
      accurainstrument
