Why Choose China Sports Court Flooring System Manufacturers for Global Projects?
  • #17115
      When an overseas contractor starts planning a basketball court, tennis court, badminton court, volleyball court, or school sports facility, one question usually comes up early in the project: where should the flooring system and related materials be sourced?
      China is one option that deserves consideration, particularly for projects that require a combination of sports flooring materials, polyurethane products, technical support, and stable factory production.
      However, choosing a China sports court flooring manufacturer should not simply be about finding a supplier with a large catalog. The more important question is whether the manufacturer understands the materials behind the system and can provide products that are suitable for the actual application.
      For buyers working on international sports flooring projects, it is useful to understand how different court flooring systems work, what materials are involved, and what to look for when evaluating a Chinese factory.
      What Is a Sports Court Flooring System?
      A sports court flooring system is a multi-layer surface designed for a particular sports application. It may be used for basketball, tennis, badminton, volleyball, pickleball, school playgrounds, and other recreational facilities.
      Depending on the system, the construction can include a concrete or asphalt base, primer, elastic layer, filler, surface coating, and line marking.
      The purpose of these layers is not simply to make the court look attractive. A properly designed system needs to provide a suitable combination of:
      • Surface traction
      • Shock absorption
      • Elasticity
      • Ball response
      • Abrasion resistance
      • Weather resistance
      • Surface stability
      • Easy maintenance
      The actual requirements depend on how and where the court will be used.
      For example, an outdoor basketball court may need stronger UV and weather resistance, while a school playground may place greater emphasis on durability and ease of maintenance.
      Why Does the Material Manufacturer Matter?
      The finished sports court may look like a simple colored surface, but several different materials can be hidden underneath it.
      The bonding layer is particularly important in systems that use polyurethane materials, rubber granules, or other composite components.
      A suitable polyurethane adhesive can help create a stable connection between different layers and materials. Poor material compatibility, inconsistent curing, or unsuitable application conditions can cause problems such as weak bonding, surface defects, or premature deterioration.
      This is why it is useful to distinguish between a company that simply sells finished flooring systems and a manufacturer with its own experience in polyurethane materials.
      Common Sports Court Flooring Options
      Different sports flooring technologies are available for different applications. Two systems worth understanding when evaluating suppliers are acrylic court flooring and Silicon PU court flooring.
      Acrylic Court Flooring System
      Acrylic flooring is commonly used for hard sports courts and can be applied to tennis courts, basketball courts, badminton courts, pickleball courts, and multipurpose school playgrounds.
      A typical acrylic system may include a primer layer, acrylic filler layer, and acrylic top coating. The filler can be combined with silica sand to help level the surface and create a consistent texture.
      JUSHU's current acrylic court flooring system uses a three-layer structure with an acrylic primer, acrylic middle layer, and acrylic top layer, followed by court line marking. The company describes the system as a seamless surface designed for professional and recreational sports applications, with properties including slip resistance, consistent ball bounce, abrasion resistance, and UV resistance.
      For overseas buyers, the important point is to evaluate the complete system rather than the top coating alone.
      The substrate, primer, middle layer, top coat, application method, and local weather conditions all affect the final result.
      Silicon PU Court Flooring System
      Silicon PU is another option for sports courts where elasticity and cushioning are important.
      According to JUSHU's product information, its Silicon PU system includes a PU primer bonding layer, an elastic Silicon PU layer, another primer bonding layer, and a UV-resistant PU top coating. It is designed for indoor and outdoor basketball, tennis, badminton, volleyball, and multipurpose school courts.
      The main difference from a conventional hard acrylic surface is the polyurethane-based resilient structure.
      For projects where impact absorption and surface elasticity are important, Silicon PU can be worth considering.
      At the same time, buyers should check the actual system structure, material specifications, application requirements, and substrate conditions before making a decision.
      Why Consider a China Sports Court Flooring Supplier?
      China's manufacturing industry has developed extensive capabilities in chemical materials, polyurethane products, rubber materials, and sports flooring components.
      For international buyers, this can provide several practical advantages.
      1. Strong Manufacturing Infrastructure
      A professional Chinese factory can manufacture different materials within a broader industrial supply chain.
      For sports flooring projects, this may include:
      • PU binders
      • Rubber-related materials
      • EPDM-related products
      • Acrylic flooring materials
      • Silicon PU systems
      • Primers
      • Surface coatings
      • Composite adhesives
      Having access to these materials through an experienced manufacturer can make technical communication easier.
      2. Experience With PU Materials
      Polyurethane is widely used in sports flooring because it can provide adhesion, flexibility, and durability.
      A manufacturer with its own PU binder development experience may have a better understanding of how polyurethane materials interact with rubber granules and other flooring components.
      This is particularly relevant when the project requires a sports court flooring adhesive rather than simply a finished surface coating.
      3. More Flexible Product Solutions
      Not every sports project has the same requirements.
      A contractor may need an acrylic system for one project and a Silicon PU system for another. A distributor may also need different materials for different regional markets.
      A manufacturer with a broader product portfolio can potentially support more than one application.
      What Should Global Buyers Check Before Choosing a China Factory?
      Finding a supplier is relatively easy. Finding the right manufacturer requires more research.
      Here are several practical points worth checking.
      Factory or Trading Company?
      First, determine whether you are communicating directly with a factory or with a trading company.
      A trading company may still be useful, but buyers who need technical information should know who actually manufactures the material.
      Ask for information about:
      • Production facilities
      • Manufacturing location
      • Product development
      • Quality control
      • Product testing
      • Technical documentation
      • Production capacity
      This can help establish whether the supplier has genuine manufacturing capabilities.
      Product Range
      A manufacturer specializing in one narrow product may be suitable for a simple purchase.
      However, for sports flooring projects, a wider range can sometimes be useful because different projects require different materials.
      Anji Jushu New Material Technology focuses on polyurethane binder research and manufacturing. Its product portfolio includes solutions related to EPDM, SBR, rubber, sports flooring, running tracks, cork, high-polymer shoe insoles, and composite adhesive applications.
      This background is relevant because polyurethane binders are used across several material systems rather than being limited to one sports flooring application.
      JUSHU as a China PU Binder Manufacturer
      Anji Jushu New Material Technology is a China-based manufacturer specializing in polyurethane PU binders.
      The company's product focus extends beyond sports court flooring and includes different PU adhesive applications.
      For sports flooring projects, this manufacturing background can be useful because the performance of a flooring system is closely related to the compatibility and quality of its bonding materials.
      JUSHU provides a dedicated sports court flooring system product category covering acrylic and Silicon PU court flooring solutions.
      The company also manufactures related PU binder products for different applications.
      For buyers who want to understand the manufacturer's broader capabilities, the JUSHU official website provides information about its product portfolio and manufacturing focus.
      What Makes a Good Sports Court Flooring Manufacturer?
      A reliable supplier should be able to discuss the project in practical terms.
      Instead of simply asking, "Which product is best?", buyers should provide information such as:
      Court type: Basketball, tennis, badminton, volleyball, pickleball, or multipurpose.
      Location: Country, climate, and whether the court is indoor or outdoor.
      Substrate: Concrete, asphalt, or another base.
      Expected usage: School, community, commercial, training, or professional use.
      Performance requirements: Traction, elasticity, cushioning, ball response, and durability.
      Maintenance conditions: Cleaning frequency and expected maintenance resources.
      This information allows the manufacturer to determine whether an acrylic, Silicon PU, or another flooring structure is more appropriate.
      Why Factory Production Can Matter for B2B Buyers
      For distributors and contractors, consistency is often more important than having a long product list.
      If the same product is required across multiple projects, batch consistency becomes an important purchasing consideration.
      Factory-based production can help manufacturers establish standardized procedures for raw material handling, formulation, production, and quality control.
      Direct communication with the factory can also make it easier to discuss technical questions.
      For example, if a contractor encounters a problem during application, being able to communicate directly with the material manufacturer can be more useful than communicating through several supply-chain layers.
      Don't Judge a Flooring System by Appearance Alone
      A common mistake in sports flooring procurement is focusing too heavily on color and surface appearance.
      A professional sports court needs more than an attractive finish.
      Two products may look similar after installation but perform differently because of differences in:
      • Base preparation
      • Primer quality
      • Binder performance
      • Elastic layer structure
      • Surface coating
      • Material compatibility
      • Installation technique
      This is why experienced contractors usually evaluate the complete system.
      For example, JUSHU's Silicon PU system includes multiple layers rather than treating the surface coating as a standalone product. Its published structure includes PU primer, Silicon PU material, another bonding layer, and UV-resistant PU top coating.
      Similarly, its acrylic system uses separate primer, middle, and top layers.
      Questions to Ask a China Sports Court Flooring Manufacturer
      Before placing an order, international buyers can ask the manufacturer:
      1. What flooring system is recommended for my court type?
      2. Is the system suitable for indoor or outdoor use?
      3. What substrate preparation is required?
      4. What primer is included?
      5. What type of adhesive or binder is used?
      6. What are the recommended application conditions?
      7. What is the complete layer structure?
      8. What maintenance is required?
      9. Can technical documentation be provided?
      10. Does the factory have experience with international projects?
      These questions can help buyers compare suppliers based on technical capability rather than marketing language.
      A Practical Approach to Selecting a China Supplier
      For overseas buyers, the selection process can be divided into four steps.
      Step 1: Define the application.
      Determine the sport, court location, climate, usage frequency, and substrate.
      Step 2: Compare flooring structures.
      Compare acrylic, Silicon PU, and other available systems based on actual project requirements.
      Step 3: Evaluate the manufacturer.
      Check factory capability, PU material experience, quality control, product range, and technical support.
      Step 4: Confirm application requirements.
      Before purchasing, confirm installation conditions, material compatibility, packaging, technical documentation, and project support.
      This approach is generally more useful than selecting a supplier based solely on product images or general claims.
      Final Thoughts
      China has become an important source of sports flooring materials and polyurethane products for international projects. For global contractors and distributors, the main advantage is not simply manufacturing scale. The real value comes from finding a factory that combines material expertise, stable production, product development, and practical application knowledge.
      A sports court flooring system should be evaluated as a complete structure. Acrylic and Silicon PU systems have different characteristics, and the appropriate choice depends on the court type, substrate, climate, expected usage, and performance requirements.
      For buyers looking for a China-based manufacturer, Anji Jushu New Material Technology is worth considering because of its focus on polyurethane binder development and production. Its sports flooring portfolio includes acrylic and Silicon PU court systems, while its broader PU binder range supports EPDM, SBR, rubber, and other applications.
      For a global B2B project, the best supplier is ultimately the one that can provide consistent materials, clear technical information, and a flooring solution that matches the actual conditions of the project.
      http://www.jushubinder.com
      Anji Jushu New Material Technology Co., Ltd.
