2025-06-23 at 1:46 pm #12951
With the development of industrial automation and high-precision processing technology, stainless steel pipelines are increasingly used in petrochemical, electric power, shipbuilding, construction, rail transit and other fields. The corresponding pipeline installation and cutting equipment has also undergone significant technological upgrades. Among them, orbital pipe cutting machinesare being adopted by more and more stainless steel pipeline installation projects with their advantages such as high efficiency, high precision and operational safety. So, what are the technical and industry driving factors behind this trend?
1. Pain points and limitations of traditional cutting methods
Before understanding the advantages of orbital pipe cutting machines, let's review the current situation and problems of traditional cutting methods.
Grinding wheel cutting machine
Traditional handheld grinding wheel cutting machines are often used for cutting small and medium diameter pipes. The advantages are cheap equipment and simple operation, but the disadvantages are also very obvious:
Low cutting accuracy, easy to have burrs and skewed cuts;
Large heat-affected zone during cutting, easy to cause discoloration or damage of stainless steel materials;
There are many splashes, and there are certain safety risks in operation;
It cannot meet the precise cutting needs of large-diameter thick-walled pipes.
Gas cutting/flame cutting
For carbon steel materials, gas cutting is a common cutting method, but it is not suitable for stainless steel cutting for the following reasons:
The high temperature generated by gas cutting can easily cause intergranular corrosion of stainless steel;
The incision is rough and deformed, and a lot of grinding and trimming are required later;
It is difficult to use in a high-clean environment indoors, with large smoke and dust and serious pollution.
Manual sawing/plasma cutting
Although the accuracy has been improved, there are still problems such as low operating efficiency, poor repeatability, and poor on-site adaptability, which makes it difficult to meet the comprehensive requirements of modern engineering for high precision, high efficiency and high safety.
2. Technical advantages of orbital pipe cutting machine
In the face of various shortcomings of traditional cutting methods, orbital pipe cutting machine came into being and quickly occupied the market of stainless steel pipe installation engineering. Its advantages are mainly reflected in the following aspects:
High-precision cutting, improving installation and docking efficiency
The orbital cutting machine realizes 360° stable rotation cutting of the whole machine through the orbit system surrounding the pipe. With plasma, electric carbon steel cutting blades or cold cutting systems, millimeter-level cutting accuracy can be achieved. This ensures that the cut is vertical, burr-free, and almost heat-affected, which greatly reduces the subsequent docking and grinding time and improves the overall pipeline installation efficiency.
Adaptable to different calibers, wide range of applications
The orbital cutting machine can be used for stainless steel pipes of various diameters such as DN50-DN1500. By replacing orbital rings or clamps of different specifications, it is easy to complete the cutting of pipes of various diameters, flexibly adapting to the needs of different project sites, especially suitable for large-scale installation projects.
Cold cutting technology to protect material performance
Many high-end orbital pipe cutting machines use cold cutting technology (cold saw or mechanical cutting method) to avoid problems such as discoloration, coarse grains, and structural weakening of stainless steel caused by high temperature. They are particularly suitable for pipeline projects with extremely high material performance requirements, such as nuclear power, pharmaceuticals, and food-grade stainless steel systems.
High operational safety and high degree of automation
Most of the equipment uses remote control or button operation to avoid direct contact between workers and high-speed rotating cutting parts, greatly improving operational safety. Some high-end equipment also supports functions such as laser positioning, automatic feeding, and intelligent monitoring, which greatly improves work efficiency and safety.
Good portability, suitable for on-site operations
The design of the orbital pipe cutting machine is aimed at on-site construction. Its main structure is light, can be quickly disassembled and assembled, and is easy to carry. It is suitable for complex environments such as overhead, narrow space, pipe gallery, field and other engineering environments.
3. Why does the stainless steel pipeline project urgently need orbital pipe cutting machines?
With the advancement of trends such as urban infrastructure upgrades, energy system transformation, and intelligent manufacturing, stainless steel pipeline installation projects have put forward higher standards for cutting equipment, and the emergence of orbital pipe cutting machines just meets this demand.
Large project volume and tight construction period
Many industrial projects often lay hundreds of kilometers of pipelines, which does not allow traditional cutting methods to operate inefficiently. The orbital pipe cutting machine not only cuts quickly and accurately, but also reduces the number of reworks, ensuring the project is delivered on time.
High quality requirements for butt welding
Stainless steel welding itself has high requirements for groove quality and edge verticality. The orbital pipe cutting machine can accurately control the cutting angle and depth, and can even complete the groove cutting in one piece, providing the best pre-treatment guarantee for automatic welding and argon arc welding.
Higher environmental protection and safety requirements
As construction safety and environmental protection standards are improved, the large amount of smoke, heat radiation, etc. generated by traditional flame cutting are gradually restricted. The orbital cutting machine achieves low-noise, flame-free, and low-dust environmentally friendly operations through mechanical or cold cutting methods.
4. Applicable industry case analysis
Petrochemical industry
A large number of stainless steel pipes are used to transport corrosive liquids or high-temperature and high-pressure media, and the welding quality requirements are extremely high. The high-precision cutting capability of the orbital cutting machine effectively guarantees the seamless connection and durability of subsequent welding.
Food and pharmaceutical industry
The cleanliness standards of stainless steel pipes in this type of industry are extremely high, and any cutting burrs or thermal deformation may become a source of pollution. The orbital cold cutting system has almost zero thermal impact and perfectly meets the clean process pipeline construction standards.
Urban gas and water supply projects
These projects often have large pipe diameters, large quantities, and complex installation locations. The orbital cutting machine has flexibility and repeatable accuracy, which can greatly improve on-site construction efficiency and reduce resource waste caused by human cutting errors.
The widespread application of orbital pipe cutting machines indicates that the installation of stainless steel pipelines has moved from traditional experience construction to a new era of high efficiency, high precision and standardization. It is not only a reflection of technological progress, but also a positive response to the concept of modern industrial engineering construction.
With the further reduction of equipment costs and the continuous upgrading of functions, orbital cutting machines will no longer be exclusive to high-end projects in the future, but will become standard tools for various pipeline projects. For enterprises, actively introducing such equipment will significantly improve project quality, customer satisfaction and brand competitiveness.
As a professional orbital pipe cutting machine supplier, we are well aware of the strict requirements of stainless steel pipeline projects for cutting efficiency, precision and construction safety. With rich industry experience and technical accumulation, we provide high-performance equipment suitable for a variety of pipe diameters and materials, which are widely used in petrochemical, electric power, shipbuilding, food and pharmaceutical fields. Our products support functions such as cold cutting, automatic feeding, laser positioning, etc., helping customers achieve standardized, high-quality and efficient on-site cutting op
https://www.nodha.com/blog/Why-choose-orbital-pipe-cutting-machine-for-stainless-steel-pipe-installa
NODHA Industrial Technology Wuxi Co., LTD -
