Why Does a Hydraulic Motor Lose Power Under Heavy Loads?
  • #18495
      Hydraulic equipment is often expected to deliver consistent power even when operating conditions become demanding. However, operators sometimes notice that a machine works normally without a load but becomes noticeably slower or weaker when handling heavy materials. In many cases, the problem is related to the hydraulic motor or the components supplying it.
      A hydraulic motor converts pressurized fluid into mechanical rotation. Its output depends on several factors, including hydraulic pressure, available flow, motor displacement and internal efficiency. When one of these factors changes, the motor may struggle to maintain the required speed or torque.
      Understanding the causes of power loss is important for equipment operators, maintenance engineers and machinery manufacturers. Identifying the problem early can help prevent unnecessary component replacement and reduce unexpected equipment downtime.
      Low Hydraulic Pressure Can Reduce Motor Torque
      Hydraulic pressure is directly related to the torque a motor can generate. When the pressure supplied to the motor falls below the required operating level, the available output torque decreases.
      This problem may not be obvious during light-duty operation. A machine can appear to work normally when resistance is low, but performance may deteriorate once the load increases.
      Several factors can contribute to insufficient pressure:
      • Incorrect pressure relief valve settings
      • Worn hydraulic pumps
      • Internal leakage in hydraulic components
      • Restricted hydraulic lines
      • Excessive mechanical resistance
      • Pressure losses across control valves
      For example, a hydraulic winch may rotate normally when the cable is unloaded. Once it begins lifting a heavy object, the motor may slow down because the available pressure cannot generate sufficient torque.
      Before replacing the motor, technicians should measure pressure under actual working conditions. Comparing unloaded and loaded readings can help determine whether the problem originates in the motor or elsewhere in the hydraulic circuit.
      A properly matched hydraulic pressure control system is essential for maintaining consistent performance under changing loads.
      Internal Leakage Can Gradually Reduce Motor Performance
      Internal leakage is another common reason for reduced hydraulic motor output.
      Hydraulic motors contain precision components that maintain the pressure difference required to generate rotation. As internal surfaces wear, clearances may increase, allowing more oil to bypass the working chambers.
      This reduces volumetric efficiency.
      The motor may still rotate, but it may require more hydraulic flow to maintain the same speed. Under heavier loads, the effect can become more noticeable.
      Different motor designs experience wear in different ways.
      Motor Type Components Requiring Attention Possible Performance Change
      Gear motor Gears and internal sealing surfaces Increased internal leakage
      Vane motor Vanes, rotor and cam ring Reduced volumetric efficiency
      Piston motor Pistons, cylinder block and valve plate Reduced pressure efficiency
      A worn hydraulic motor assembly may also produce excessive heat because more energy is lost through internal leakage.
      In some cases, technicians can identify the problem through case drain measurements, operating temperature checks and performance comparisons.
      Replacing the motor without checking hydraulic oil cleanliness or system pressure may lead to similar wear in the replacement unit.
      Hydraulic Oil Condition Has a Direct Effect on Motor Reliability
      Hydraulic oil performs several jobs simultaneously. It transfers energy, lubricates moving surfaces, helps remove heat and protects internal components from excessive wear.
      When oil becomes contaminated or its viscosity changes significantly, motor performance can deteriorate.
      Solid particles are particularly harmful to precision hydraulic components. Metal debris, dust and degraded seal material can damage internal surfaces and interfere with normal operation.
      Water contamination creates additional problems by reducing lubrication quality and increasing the risk of corrosion.
      Operators should pay attention to several oil-related conditions:
      1. Oil viscosity outside the recommended operating range
      2. Excessive contamination
      3. Water entering the hydraulic reservoir
      4. Degraded oil after prolonged operation
      5. Filters becoming restricted
      For equipment operating in marine environments, moisture control deserves particular attention. Temperature fluctuations and humid conditions can increase the risk of water contamination.
      A suitable hydraulic oil filtration system helps protect pumps, motors and valves from premature wear.
      Oil analysis can also provide useful information about contamination and abnormal wear particles before serious damage occurs.
      Excessive Operating Temperature Can Affect Motor Efficiency
      Heat is not necessarily a sign of motor failure, but consistently high operating temperature should not be ignored.
      When hydraulic oil becomes too hot, its viscosity decreases. This can increase internal leakage and affect lubrication between moving components.
      The result may be reduced efficiency, unstable output and accelerated component wear.
      Common sources of excessive heat include:
      • Continuous operation at high pressure
      • Excessive internal leakage
      • Restricted return lines
      • Incorrect valve settings
      • Undersized hydraulic components
      • Insufficient cooling capacity
      A machine operating under heavy loads for extended periods is particularly vulnerable if its cooling system is not designed for the actual duty cycle.
      For this reason, hydraulic motor overheating should be investigated together with pump performance, valve pressure losses and oil temperature.
      Simply installing a larger motor will not necessarily solve the problem.
      The hydraulic circuit needs to be checked to determine where excessive energy is being converted into heat.
      Incorrect Motor Matching Can Cause Repeated Power Problems
      Not every hydraulic motor is suitable for every machine.
      Even when two motors have similar external dimensions, their displacement, pressure ratings, torque characteristics and speed ranges may differ.
      A motor that is too small for the application may struggle under heavy loads.
      A motor with an unsuitable displacement may also operate outside the required speed range.
      Before selecting a replacement hydraulic motor, engineers should confirm several technical parameters.
      Selection Factor What Should Be Checked
      Displacement Required speed and torque relationship
      Operating pressure Normal and maximum system pressure
      Hydraulic flow Available pump output
      Starting torque Torque required to overcome initial resistance
      Continuous torque Torque required during normal operation
      Duty cycle Operating hours and frequency of starts
      Installation Shaft, mounting and port configuration
      The mechanical transmission also matters.
      A gearbox can change the relationship between motor speed and output torque. If the gear ratio is incorrectly selected, the machine may not achieve the expected performance even when the motor itself is functioning correctly.
      For heavy-duty equipment, motor selection should therefore be based on the complete drive system rather than one specification.
      Practical Maintenance Steps to Prevent Unexpected Motor Failure
      Most hydraulic motor problems become easier to manage when operating conditions are monitored regularly.
      Instead of waiting until equipment loses power completely, maintenance teams can record changes in pressure, temperature, speed and oil condition.
      A practical inspection routine should include:
      • Checking hydraulic oil level and condition
      • Inspecting filters and suction lines
      • Measuring operating pressure
      • Monitoring oil temperature
      • Checking external leakage
      • Listening for unusual operating noise
      • Inspecting motor mounting and shaft alignment
      • Comparing actual performance with normal operating values
      For marine equipment, salt exposure and vibration should also be considered. External corrosion around connections and mounting points can create additional maintenance problems.
      When abnormal performance appears, technicians should distinguish between hydraulic and mechanical causes.
      For example, a winch that struggles to lift may have insufficient motor torque, but excessive gearbox friction or a partially engaged mechanical brake can produce similar symptoms.
      Replacing components without identifying the original fault often results in repeated maintenance.
      A structured inspection process helps determine whether the motor needs adjustment, repair or complete replacement.
      A hydraulic motor that loses power under heavy loads does not necessarily have an internal mechanical failure. Insufficient pressure, reduced pump flow, internal leakage, contaminated oil and excessive operating temperature can all contribute to declining performance.
      The most effective troubleshooting approach is to examine the complete hydraulic system before replacing individual components.
      For equipment manufacturers and maintenance teams, correct motor matching and regular oil condition monitoring are equally important. A motor operating within its intended pressure, speed and torque range is more likely to deliver consistent performance throughout its service life.
      Whether used in marine machinery, industrial equipment, winches or hydraulic drive systems, reliable operation depends on the relationship between the motor and the hydraulic circuit supplying it.
      http://www.ntilmm.com
      Nantong Chengliang Marine Machinery Manufacturing Co., Ltd.
