2025-12-18 at 10:48 am #14668
Maintaining a clean and safe workshop environment is critical for productivity, worker health, and equipment longevity. In industrial facilities where machining, cutting, and metalworking take place, oil mist and smoke are inevitable byproducts that can impact air quality and cause equipment contamination.
At Wuxi BODHI Environmental Technology Co., Ltd., our range of Stand-Only Centrifugal Oil Mist Collectors—including the HCY-W1, HCY-D1, HCY-W5, HCY-W8, and HCY-LS2—are designed to address these challenges efficiently.
Efficient Oil Mist and Smoke Removal
Our Stand-Only Centrifugal Oil Mist Collectors use high-speed centrifugal separation to capture oil particles and smoke from the air. This technology ensures:
Cleaner air for workers – Reducing respiratory irritation and improving overall comfort.
Safer working conditions – Minimizing flammable mist accumulation that could pose fire hazards.
Equipment protection – Preventing oil deposition on machines, electronics, and surfaces.
Why Every Workshop Needs One
Universal Industrial Application
Whether in CNC machining, metal cutting, or grinding operations, oil mist is a common byproduct. Every workshop generating such particulates benefits from localized collection.
Standalone and Flexible Installation
No complex ducting or centralized systems are required. Stand-Only collectors can be positioned directly where the oil mist is produced, making retrofitting in existing workshops easy.
Low Maintenance and Cost-Effective
With long-life centrifugal filters and easy cleaning, these units reduce consumable costs while ensuring continuous operation.
Improved Air Quality & Regulatory Compliance
Cleaner air supports worker health, reduces downtime, and helps workshops meet local air quality and safety standards.
BODHI Stand-Only Centrifugal Oil Mist Collector Series
– Compact and efficient for small-to-medium workshops.
– Dual-stage separation for higher oil mist removal efficiency.
– Medium capacity solution for larger workshops.
– High-capacity unit suitable for heavy industrial operations.
– Advanced model for precision machining and sensitive environments.
Every workshop that generates oil mist and smoke can benefit from installing a Stand-Only Centrifugal Oil Mist Collector. These units provide a localized, efficient, and cost-effective solution to improve air quality, protect workers, and enhance equipment longevity.
For reliable industrial air purification solutions, Wuxi BODHI Environmental Technology Co., Ltd. offers a complete series of Stand-Only Centrifugal Oil Mist Collectors tailored for workshops of all sizes.
https://www.bodhicollector.com/why-every-workshop-needs-a-stand-only-centrifugal-oil-mist-collector.
Wuxi BODHI Environmental Technology Co., Ltd. -
