Why Small Design Decisions Can Change the Cost of Custom Metal Parts
  • #17512
      A custom metal part can look simple on a drawing and still be surprisingly expensive to produce.
      The reason is rarely the raw material alone. Production cost is influenced by how the part is cut, formed, positioned, inspected, finished, packed, and eventually assembled. A hole moved by a few millimeters, an unnecessarily tight tolerance, or a bend placed too close to another feature can create additional operations that are difficult to see in the original design.
      For engineers and product developers, the most useful time to control these costs is before production begins. Small design decisions made during the drawing stage can have a much larger financial impact than negotiating a lower piece price after the tooling and manufacturing process have already been defined.
      Material Utilization Starts With the Part Layout
      Material waste is one of the easiest costs to overlook because it does not always appear on a supplier quotation as a separate charge.
      For sheet metal parts, the way individual blanks are arranged on a sheet affects how much material remains after cutting. Large unused areas between parts increase scrap, while poorly positioned holes or cutouts can make nesting less efficient.
      This becomes more important as production volume increases. A small amount of additional scrap on one part may seem insignificant, but thousands of production cycles can turn it into a substantial cost.
      Designers can often improve material utilization by considering the overall blank shape earlier in development. Standardizing dimensions where practical, avoiding unnecessary irregular contours, and reviewing how adjacent parts could be nested can all help.
      The goal is not simply to use less metal. It is to create a design that makes efficient use of the material while still meeting the functional requirements of the product.
      Tolerances Should Match the Function
      Tighter tolerances usually require more control during manufacturing.
      That does not mean every dimension should have a generous tolerance. Critical interfaces may genuinely require precise dimensions. The problem occurs when tight tolerances are applied to features that have little effect on the finished product.
      For example, a mounting hole that interfaces with a precision component may need close dimensional control, while an external edge hidden inside an enclosure may not.
      Different manufacturing processes also have different practical tolerance capabilities. A tolerance that is straightforward for CNC machining may require additional operations when applied to a formed sheet metal component.
      A useful drawing therefore distinguishes between functional dimensions and non-critical dimensions.
      This approach gives the manufacturer more freedom to select an efficient production method without compromising the performance of the finished assembly.
      Bend Design Can Affect More Than the Bending Operation
      Bends are another area where seemingly minor design choices can create manufacturing complications.
      A bend placed too close to a hole or another bend may cause distortion, cracking, deformation, or interference with tooling. In some cases, the manufacturer may need an additional operation to achieve a geometry that could have been produced more efficiently with a small design adjustment.
      Bend radius also matters. Extremely small inside radii may be unsuitable for certain materials or thicknesses, while unnecessarily large radii can increase the space required by the component.
      The practical solution is to consider the material, thickness, bend radius, grain direction, and bend sequence together.
      This is particularly important for enclosures and brackets that contain multiple bends. A part may appear straightforward in its flat pattern but become considerably more difficult once the actual forming sequence is considered.
      Hole Placement Can Influence Production Efficiency
      Holes are often treated as simple features, but their position and size can affect both tooling and production speed.
      Closely spaced holes may leave insufficient material between them. Holes positioned too close to an edge can create deformation during punching or forming. A large number of different hole sizes can also increase tooling complexity when the part is produced by stamping.
      Standardizing hole sizes where the application allows it can simplify production. If several fasteners can use the same hole diameter, the number of required tools may be reduced.
      For high-volume components, these small changes can become meaningful because tooling efficiency and cycle time are repeated across the entire production run.
      For lower-volume parts, the same design decisions may instead affect setup time and programming effort.
      Choosing the Process Before the Design Is Locked
      A common mistake is to complete the geometry first and decide how to manufacture it afterward.
      The better approach is to consider manufacturing technology while the design is still flexible.
      A part produced in small quantities may be economical to laser cut and bend. A similar component produced in very large quantities could justify dedicated tooling and a stamping process.
      CNC machining may make sense when the component contains complex three-dimensional features or requires tight dimensional control. Sheet metal fabrication can be more efficient for larger enclosures and structural panels.
      For projects involving high-volume stamped components, understanding the capabilities of custom metal stamping during the design stage can prevent unnecessary features from being built into the tooling.
      The important point is that the most economical process depends on more than the part's shape. Production volume, material, tolerances, tooling investment, cycle time, and downstream operations all matter.
      Finishing Requirements Can Add Hidden Complexity
      Surface finishing is another area where design requirements can become more expensive than expected.
      A component may require powder coating, plating, anodizing, polishing, or another treatment depending on its environment and appearance requirements. But the geometry of the part can influence how easily the finish is applied.
      Deep recesses, narrow gaps, inaccessible surfaces, and tightly spaced features may create coating or cleaning challenges. Parts that require masking also need additional preparation and handling.
      Finishing should therefore be considered when defining the geometry rather than treated as a completely separate step at the end of development.
      If a surface will never be visible or exposed to the environment, an unnecessarily elaborate finish may provide little practical value.
      Assembly Time Is Part of Manufacturing Cost
      The cheapest individual component is not necessarily the cheapest component to use.
      A metal part that costs slightly less to manufacture may require several additional assembly steps. Another design may cost more per piece but integrate mounting features that eliminate separate brackets, fasteners, or secondary operations.
      This is why cost analysis should extend beyond the manufacturing quotation.
      Designers should ask:
      • How many separate components are required?
      • Can mounting features be integrated into the part?
      • Can standard fasteners replace specialized hardware?
      • Does the part require manual alignment?
      • Are additional welding or assembly operations necessary?
      • Can the finished component be installed quickly on the production line?
      A small increase in fabrication cost can sometimes reduce total assembly cost enough to make the overall product more economical.
      Prototyping Should Test Manufacturability, Not Just Function
      A prototype is often used to determine whether a product works as intended. It should also reveal whether the production design makes sense.
      Early prototypes can expose problems such as difficult bend sequences, inaccessible fasteners, poor fit between components, unexpected deformation, or unnecessary machining.
      At this stage, design changes are relatively inexpensive. Once production tooling has been completed, the same modification may require tooling changes, new samples, additional inspection, and schedule adjustments.
      This is why a prototype should be treated as an opportunity to refine the manufacturing process rather than simply as a visual sample.
      For OEM projects, an experienced manufacturer can also provide practical feedback on the drawing before production begins. Services covering OEM metal manufacturing can be particularly useful when the product involves several manufacturing processes rather than a single operation.
      Good Cost Control Begins With Better Engineering
      Reducing the cost of custom metal parts is rarely about removing one expensive operation at the last minute.
      The bigger gains usually come from dozens of small decisions made earlier: sensible tolerances, efficient material use, practical bend geometry, standardized holes, appropriate finishing, and a manufacturing process suited to the production volume.
      These choices also improve more than price. A part designed with manufacturing in mind is often easier to inspect, easier to assemble, and more consistent in long-term production.
      For engineers, the most effective cost reduction strategy is therefore not simply to ask a manufacturer for a lower quotation. It is to make the drawing easier to manufacture without compromising what the part actually needs to do.
      That is where thoughtful design has its greatest value: before the first production run, when a small change on a drawing can still prevent a much larger cost later.
      http://www.kingsiumetal.com
      kingsiu
