WILLSTRONG® Projects: Curved and Perforated Aluminum Facades in Global Architecture
  • #17375
      Architectural facade design is moving beyond simple building protection. Today, architects and developers increasingly expect facade materials to contribute to visual identity, spatial experience, environmental interaction, and overall building performance.
      Award-winning buildings often demonstrate this shift particularly well. The ERDOS Cashmere Tech Centre, recognized as an Architizer A+Awards Jury Winner, provides an example of how customized aluminum facade systems can become an integral part of architectural expression.
      The WILLSTRONG® Projects portfolio offers another perspective on this development. Through applications involving curved aluminum panels, perforated aluminum panels, and customized aluminum composite panel systems, these projects show how facade engineering can support distinctive architectural concepts while maintaining the practical advantages of aluminum-based materials.
      Aluminum Facades as Part of Architectural Expression
      A facade is one of the first elements people notice when approaching a building. Its shape, rhythm, texture, transparency, and relationship with light can influence how the entire structure is perceived.
      Traditional flat panels can provide a clean and efficient envelope, but more complex architectural concepts may require customized forms. Curved panels can introduce flowing lines and visual movement, while perforated panels can create different levels of transparency, shadow, and texture.
      The challenge is that distinctive forms require more than an attractive concept. Panel geometry, fabrication accuracy, material selection, installation tolerances, and coordination between design and construction teams all influence whether the intended facade can be achieved.
      This makes project experience particularly valuable when unusual aluminum facade systems are involved.
      Curved Aluminum Panels Create Dynamic Building Forms
      Curved aluminum panels can transform a conventional facade into a more fluid architectural surface. Instead of relying exclusively on straight horizontal or vertical lines, designers can use curves to create movement, depth, and visual continuity.
      The ERDOS Cashmere Tech Centre demonstrates this concept through carefully arranged curved aluminum elements. The facade's flowing forms create a stronger visual connection between different areas of the building and can influence how people perceive movement around the structure.
      Curved panels can also provide architects with greater freedom when developing distinctive building envelopes. Customized panel geometry allows facade surfaces to follow more complex design concepts while retaining the lightweight and durable characteristics associated with aluminum.
      However, curved facade construction requires careful manufacturing and installation coordination. Panel dimensions, bending accuracy, connection details, supporting structures, and installation sequences all need to work together.
      For this reason, the feasibility of curved aluminum facade designs should be considered during the engineering stage rather than treated solely as an aesthetic decision.
      Perforated Aluminum Panels Add Texture and Transparency
      Perforated aluminum panels provide a different design approach. Instead of emphasizing three-dimensional curves, they use controlled openings to create patterns, texture, shadow, and varying degrees of visual permeability.
      This can help prevent a large facade from appearing excessively solid. Depending on the perforation pattern and application, the panels may create visual connections between indoor and outdoor areas while maintaining a defined building envelope.
      Perforated aluminum systems can also interact strongly with changing daylight. Sunlight passing through the openings can produce shifting shadows and visual effects across the facade, giving the building a changing appearance throughout the day.
      From an architectural perspective, perforation patterns can be customized according to the project's visual language. From a functional perspective, the design may also be considered in relation to daylight management, ventilation, screening, and other facade requirements.
      This makes perforated aluminum panels relevant to commercial buildings, hotels, cultural projects, public facilities, and other developments where appearance and facade functionality need to work together.
      What the ERDOS Cashmere Tech Centre Demonstrates
      The ERDOS Cashmere Tech Centre illustrates how facade materials can influence more than the external appearance of a building.
      The combination of curved aluminum panels and perforated surfaces creates multiple layers across the building envelope. Curved forms contribute movement and visual direction, while perforated areas introduce texture and a degree of openness.
      The project demonstrates an important principle for contemporary facade design: material selection and architectural form should be considered together.
      When aluminum panels are developed specifically around the geometry and requirements of a building, they can become part of the architectural concept instead of functioning simply as a finishing layer.
      This approach also highlights why customized facade manufacturing capabilities are increasingly important for projects with non-standard forms.
      Curved Aluminum Application: Andaman Riviera Phuket Hotel
      The Andaman Riviera Phuket Hotel Project provides another example of customized curved aluminum facade construction.
      For this project, WILLSTRONG® used curved modular aluminum composite panels to create a distinctive exterior appearance. Compared with conventional flat ACP systems, curved modular panels require greater attention to shaping, dimensional control, production accuracy, and installation coordination.
      The customized panels help establish continuous visual lines across the hotel facade. Rather than appearing as isolated decorative elements, the curved surfaces contribute to the overall architectural identity of the building.
      For hospitality projects, this type of facade treatment can be particularly valuable because the exterior is closely connected with first impressions and brand identity. A distinctive facade can help a hotel or resort create a recognizable visual character.
      At the same time, curved ACP systems need to maintain practical requirements related to weather exposure, panel stability, installation, and long-term maintenance. This makes engineering capability an important consideration alongside design creativity.
      Perforated Aluminum Application: Australia Project
      Perforated aluminum systems provide another route for creating architectural depth.
      In the 2025 Australia Perforated Corrugated Panel Project, WILLSTRONG® applied customized perforated aluminum solutions to develop a more textured facade appearance.
      The controlled perforation pattern changes how the surface interacts with light and shadow. Depending on viewing angle and lighting conditions, the facade can present different visual effects, creating greater depth than a completely solid panel surface.
      This approach demonstrates how perforation can be used as an architectural design tool rather than simply as a manufacturing technique.
      The appropriate pattern, opening ratio, panel configuration, and installation method can be developed according to the design intent and functional requirements of the project.
      For architects working on large building surfaces, perforated panels can therefore provide an alternative to completely flat and visually uniform facade treatments.
      From Individual Projects to Broader Facade Solutions
      Individual projects can reveal how advanced facade systems perform in actual construction environments. They also demonstrate the importance of adapting technology to different architectural requirements.
      The principles seen in award-winning architecture—custom geometry, material flexibility, visual rhythm, and interaction with light—can be applied to many types of commercial and public buildings.
      WILLSTRONG® has developed facade products since 1995 and provides solutions including aluminum composite panels, fire-resistant composite panels, and aluminum honeycomb systems.
      The company reports more than 100,000 completed cases, projects and customers across more than 80 countries and regions, and more than 30 certifications worldwide.
      This experience provides a broader foundation for projects where architects and contractors require customized aluminum facade systems rather than standardized panel configurations.
      Why Engineering Matters in Customized Facades
      A complex facade concept can only succeed if it can be manufactured and installed accurately.
      Curved panels require controlled shaping and dimensional consistency. Perforated panels require accurate pattern production and appropriate structural consideration. Both systems need to be coordinated with the building's supporting structure and installation conditions.
      Engineering review can identify potential issues before production begins. These may include panel dimensions, connection methods, installation tolerances, material behavior, transportation requirements, and the relationship between facade modules.
      For large international projects, coordination becomes even more important because manufacturing conditions, construction practices, climate, building regulations, and site conditions can vary considerably between regions.
      A supplier with experience in international facade projects can therefore contribute more than material production. Technical communication and project coordination can also influence the efficiency of the overall process.
      Aluminum Facades for Different Architectural Requirements
      There is no single facade configuration that works for every building.
      A hotel may prioritize distinctive curves and strong visual identity. A commercial building may require a combination of texture and solar screening. A cultural facility may use perforated surfaces to create patterns related to its architectural concept.
      Likewise, different projects may require different combinations of panel types. Flat ACP panels, curved aluminum panels, perforated panels, fire-resistant composites, and honeycomb panels can be selected according to the specific facade design.
      The objective is not simply to use the most complex panel available. Instead, the facade system should provide an appropriate balance between appearance, performance, manufacturability, installation requirements, and project budget.
      International Project Experience
      WILLSTRONG®'s project experience extends beyond individual architectural applications. International projects such as the 2019 UAE Project and 2025 Tanzania Project demonstrate the company's involvement in facade applications across different markets.
      International facade projects often require suppliers to adapt to different environmental conditions and construction requirements. Material selection, installation planning, technical documentation, logistics, and quality control all become important parts of project execution.
      Experience across multiple regions can provide useful insight when customized facade products are being specified for overseas construction projects.
      For architects and contractors, reviewing a supplier's completed project portfolio can help provide a clearer understanding of how its products perform beyond product brochures and standard specifications.
      The Role of Aluminum in Modern Facade Design
      Aluminum continues to attract attention in contemporary facade construction because it combines relatively low weight with durability and design flexibility.
      Its ability to be fabricated into different panel configurations allows architects to explore a wide range of facade expressions. Smooth flat surfaces can create a minimalist appearance, while curves can introduce movement and perforations can create texture and transparency.
      The material can therefore support both functional and visual objectives.
      However, successful facade design depends on the complete system. Panel material, surface treatment, structural support, connection details, manufacturing tolerances, and installation procedures should be considered together.
      This systems-based approach is particularly important for large or geometrically complex projects.
      How Award-Winning Concepts Influence Future Facade Design
      Projects recognized by major architectural awards can provide useful insight into broader design trends. The ERDOS Cashmere Tech Centre demonstrates how facade materials can contribute directly to architectural storytelling.
      The use of curved forms creates visual movement, while perforated surfaces provide another layer of interaction between the building and its surroundings.
      Similar ideas are appearing in contemporary commercial, hospitality, cultural, and public architecture. Designers increasingly use customized facade elements to give buildings stronger identities rather than relying solely on conventional rectangular envelopes.
      At the same time, these concepts require manufacturers to move beyond standard panel production and develop stronger capabilities in customization, engineering, fabrication, and project support.
      Choosing a Facade Partner for Customized Projects
      When evaluating an aluminum facade supplier, buyers should look beyond individual product specifications.
      Useful considerations include:
      • Experience with customized facade systems
      • Curved panel manufacturing capability
      • Perforated panel production
      • Material and panel options
      • Engineering and technical support
      • International project experience
      • Quality-control procedures
      • Relevant certifications
      • Production capacity
      • Installation and project coordination support
      A supplier's completed projects can also provide valuable evidence of its ability to translate architectural drawings into finished facade systems.
      For complex projects, early communication between architects, contractors, engineers, and panel manufacturers can help reduce fabrication and installation risks.
      From Architectural Concept to Completed Facade
      The most successful customized facade projects usually involve a process that begins well before manufacturing.
      First, the architectural concept needs to be translated into practical panel geometry. Next, engineering teams can review material selection, structure, connections, tolerances, and installation requirements. Production can then be organized around the approved design, followed by inspection, packaging, transportation, and site installation.
      This workflow helps ensure that the visual concept is supported by a practical construction solution.
      The ERDOS Cashmere Tech Centre and other international projects demonstrate the potential of this approach. Curved and perforated aluminum systems can create distinctive architectural effects, but their success depends on the ability to combine design intent with manufacturing and engineering execution.
      Modern facade design increasingly treats the building envelope as an active part of architectural identity. Curved aluminum panels can introduce movement and continuity, while perforated aluminum panels can add texture, transparency, shadow, and visual depth.
      The ERDOS Cashmere Tech Centre, recognized with an Architizer A+Awards Jury Winner award, demonstrates how these techniques can contribute to an award-winning architectural concept. Other international applications, including the Andaman Riviera Phuket Hotel Project and the 2025 Australia Perforated Corrugated Panel Project, show how similar aluminum facade principles can be adapted to different building types and markets.
      For architects, developers, and contractors planning customized facade projects, the key is to evaluate design possibilities together with manufacturing precision, engineering support, material performance, and project coordination.
      With decades of experience in aluminum facade development and a broad international project portfolio, WILLSTRONG® Projects provides examples of how customized aluminum facade systems can turn complex architectural ideas into practical building envelopes.
      When researching suppliers for curved aluminum panels, perforated facade systems, ACP solutions, or other customized exterior applications, the project experience and technical capabilities of WILLSTRONG® can be considered as part of the overall supplier evaluation.
      https://www.willstrong360.com
      WILLSTRONG®
