Working principle of integrated ice maker machine: analysis of cooling, water circulation and ice making process
  • #3307
      With the continuous advancement of technology, integrated ice maker machine has become one of the indispensable equipment in modern homes and commercial places. These machines create refreshing ice quickly and efficiently through complex cooling systems, water circulation systems and ice-making processes. This article will delve into the basic working principles of integrated ice maker machine to help readers better understand this modern refrigeration equipment.
      1. Cooling system
      The cooling system of the integrated ice maker machine is the core part of the ice making process. It consists of compressor, condenser, evaporator and expansion valve. First, the compressor compresses the refrigerant into high-pressure gas and then sends it to the condenser. In the condenser, the high-pressure gas releases heat by dissipating heat and becomes a high-pressure liquid. Next, the high-pressure liquid enters the evaporator through the expansion valve. At this time, the pressure decreases and the liquid turns into low-pressure evaporation gas. In the evaporator, the refrigerant absorbs heat from the surrounding environment, causing the internal temperature of the evaporator to decrease. Finally, the low-pressure evaporated gas enters the compressor again and circulates again, forming a closed loop of the cooling system.
      2. Water circulation system
      The water circulation system of the integrated ice maker machine is responsible for converting water into ice cubes. It consists of water tank, water pump, water pipe and nozzle. First, the water pump draws water from the tank and delivers it through the water pipe to the nozzle. The nozzle will spray water evenly over the surface of the evaporator. In the evaporator, the water is affected by the low temperature inside the evaporator, gradually cooling and forming ice. After the ice cubes form, the water pump will stop supplying water. When the ice cubes melt, the water pump will restart and the cycle will repeat.
      3. Ice making process
      The ice making process is the ultimate goal of integrated ice maker machine. When the cooling system and water circulation system are operating normally, the ice making process begins. First, the cooling system will lower the temperature inside the evaporator to a point where the water sprayed on the evaporator begins to freeze. Over time, the ice cube will grow until it reaches the set size. Once the ice cubes reach the predetermined size, the ice making process automatically stops and the ice cubes are stored in the storage area of the integrated ice maker machine, waiting for use.
      The integrated ice maker machine can efficiently create fresh ice cubes through the synergy of the cooling system, water circulation system and ice making process. The cooling system realizes the circulation of refrigerant through components such as compressors, condensers, evaporators, and expansion valves. The water circulation system converts water into ice cubes through components such as water pumps, water pipes, and nozzles. The ice making process is the ultimate goal of the entire workflow. By controlling temperature and time, ice cubes are manufactured and stored. An in-depth understanding of the working principle of integrated ice maker machine will help us better use and maintain this modern refrigeration equipment.
      https://www.gdyuebingli.com/Refrigerated-commercial-tool-four-door-vertical-freezer-appearance-characterist.html
      Vivi
      838792590@qq.com
