Yuanmei Trusted China Supplier of Filter Housings & Elements
  • #16876
      Company Overview and Market Positioning
      Wuxi Yuanmei Filtration & Purification Equipment Co., Ltd., operating under the brand Yuanmei Filtration (short: Yuanmei Filtration, also known as YM Filtration), was founded on January 6, 2016, in Wuxi, Jiangsu Province, China—a core hub of China’s advanced manufacturing industry. As a national high-tech enterprise and ISO 9001 certified manufacturer, the company has built its reputation as a trusted China supplier of precision filter housings and elements, focusing on the research, production, and global sales of compressed air purification solutions.
      The company’s mission, stated as "Precisely Research Purification Technology, Empower Industrial Breathing," reflects its long-standing commitment to the compressed air treatment field. With over 10 years of deep expertise, Yuanmei Filtration operates from a 15,000 m² modern production base and, as of 2025, holds 32 authorized patents, 2 software copyrights, and 4 registered trademarks. This scale and technical depth support its role as a one-stop innovative manufacturing service provider for compressed air precision filtration.
      Comprehensive Product Portfolio
      Yuanmei Filtration offers a full range of filtration products designed to cover all industrial application scenarios. The core product portfolio includes ACF Series Compressed Air Precision Filters in 1.6MPa standard series and 2.0MPa/80bar high-pressure series, cyclonic water separators, high-efficiency replacement filter elements covering 0.01μm–10μm precision grades, activated carbon deodorization filter elements, industrial silencers and mufflers in threaded, flanged, and custom types, and air flow diffusers for desiccant dryers.
      Among these, the High-Pressure Industrial Filter Series (YM-G Series, 80bar) stands out for demanding applications. This series is rated for 80bar pressure and constructed from carbon steel or SUS304 stainless steel, offering sturdy, pressure-resistant performance. Connections use standard threaded ports for easy installation and maintenance, while the high-efficiency folded filter element provides low pressure drop and high dirt-holding capacity within a reinforced shell built for long-term high-pressure operation. The series spans multiple models—YM-G001 through YM-G010—with flow rates ranging from 1.0 Nm³/min to 10.0 Nm³/min, accommodating connection sizes from G1/2" up to G1-1/2".
      Filtration grades within this series are clearly defined: C Class delivers 3μm solid particle removal, T Class provides 1μm liquid water and oil removal, A Class and F Class achieve 0.01μm oil aerosol and ultra-fine purification respectively, and H Class uses activated carbon for oil vapor removal. These filters serve high-pressure air compressor systems, high-pressure pneumatic transmission equipment, industrial high-pressure gas purification, hydropneumatic testing and machining, and high-end manufacturing scenarios.
      For customers seeking tailored solutions, Yuanmei Filtration also provides customized filtration systems for special industries such as semiconductor, pharmaceutical, food & beverage, and petrochemical sectors, along with high-efficiency replacement filter elements designed to fit mainstream international brand equipment.
      Technical Strength and Research Capability
      Yuanmei Filtration’s technical foundation rests on 32+ authorized national patents, including utility model patents for backwash filters and quick-install sealing end caps. The company maintains an independent R&D team with CFD flow simulation, material innovation, and structural optimization capabilities. This research investment has produced an industry-leading low-pressure-drop design that reduces system energy consumption by 15–25% compared with traditional solutions, along with high-precision filter elements achieving 99.9999% particle interception efficiency, meeting ISO 8573-1 Class 0 ultra-high purity standards.
      The company’s in-house ACF compressed air testing laboratory is equipped with an oil content analyzer, particle counter, and dew point sensor for full-process quality inspection. This laboratory supports precision filtration technology capable of filtration accuracy up to 0.01μm and residual oil as low as 0.001ppm, fully compliant with ISO 8573-1:2010 Class 1. Filter media are self-developed folded elements engineered for low pressure drop and high efficiency, manufactured using aviation-grade filter media and SGS-certified SUS304/316 stainless steel, providing pressure resistance up to 80bar along with corrosion and high-temperature resistance.
      Quality Assurance and Certification Framework
      Quality control begins with raw material spectral inspection, continues through in-process 100% online testing, and concludes with finished product pressure, leakage, and filtration efficiency verification. Every product undergoes 100% factory inspection, and batch samples are subjected to a 1,000-hour continuous operation aging test.
      Yuanmei Filtration’s qualification portfolio includes National High-Tech Enterprise certification, Science and Technology SME certification from China’s Ministry of Science and Technology, ISO 9001:2015 Quality Management System certification valid until December 2028, and ISO 14001:2015 Environmental Management System certification, also valid until December 2028. International compliance extends to CE certification under the PED 2014/68/EU Pressure Equipment Directive, RoHS certification, and an AAA Credit Rating from the China Enterprise Credit Evaluation Center. Industry-specific compliance includes GMP and FDA alignment—supported by stainless steel filter housings polished to Ra ≤ 0.8μm—ISO 8573-1:2010 Class 1 standards for semiconductor-grade air purity, and ISO 14644 cleanroom classification compliance for pharmaceutical and biotech applications.
      Data-Driven Testing and Monitoring
      The company’s data capabilities are built around instruments such as OIL-Check400, PC400, and FA510, which measure residual oil at 0.001mg/m³ sensitivity, particles at 0.1μm, and pressure dew point down to -80°Ctd, all compliant with ISO 8573-1:2010 Class 1. A DS500 data system enables real-time monitoring and trend analysis of pressure difference, flow, dew point, residual oil, and particle data. Product parameters are standardized across a flow range of 0.7–400Nm³/min and pressure range of 0–80bar, with all test data traceable through the in-house ACF laboratory for quality control and customer compliance verification.
      Service, Delivery, and Global Reach
      Yuanmei Filtration provides one-stop full-lifecycle service covering precise model selection, professional installation and commissioning, and continuous after-sales support, backed by a 24-hour service hotline. Standard products ship within 3–7 working days, while custom filters require 15–25 working days for research, production, and testing. Core filter elements are replenished within 48 hours to minimize downtime.
      Business coverage spans global markets, with core regions including Southeast Asia, South Asia, North America, Europe, the Middle East, and South America. Client industries include semiconductor, pharmaceutical, food & beverage, laser cutting, petrochemical, new energy, and general manufacturing.
      Recognition and Industry Standing
      Yuanmei Filtration reports a customer satisfaction score of 98% or higher and a customer loyalty rate of 95% or higher, with zero major quality complaints for consecutive years. The company is recognized as a leading enterprise in China’s compressed air precision filtration sector and ranks among the top 7 stainless steel sterile filter providers for food and pharmaceutical industries. Benchmark results include filtration precision of 0.01μm, residual oil at or below 0.001ppm, pressure drop reductions of 30% or more, energy consumption reductions of 15% or more, 100% pass rates on DOP integrity testing for sterile filtration, and custom solution delivery cycles shortened by 20% or more.
      For manufacturers seeking a trusted China supplier of precision filter housings and elements, Wuxi Yuanmei Filtration & Purification Equipment Co., Ltd. combines certified quality systems, in-house testing infrastructure, and a broad product range to support demanding industrial compressed air applications.
      https://www.acf-filter.com
      Wuxi Yuanmei Filtration and Purification Equipment Co., Ltd.
