2026-11-12 at 4:41 pm #18385
Maintaining reliable diesel engine performance requires attention to both timing components and internal moving parts. During an engine overhaul, wear in one component may also indicate a need to inspect connected parts before reassembly. For workshops servicing ZK6138 buses equipped with the WP10.375 engine, accurate component identification and systematic inspection can help reduce repeat repairs and avoid incorrect spare parts orders.
The Weichai Bus Engines for ZK6138 1000-00514 Connecting Rod, 1004-00286 Connecting Rod Bushing, 1005-00940 Crankshaft Timing Gear range includes several engine components that should be identified by their individual part numbers and intended applications. The 1005-00940 crankshaft timing gear is relevant when examining the engine's mechanical timing system, while the connecting rod and its bushing serve different functions within the piston and crankshaft assembly. Understanding these differences helps maintenance teams plan repairs and prepare accurate purchasing lists.
Understanding the Crankshaft Timing Gear in a Weichai Bus Engine
The crankshaft timing gear helps maintain the required mechanical relationship between the crankshaft and other synchronized engine components. Correct timing is essential to the engine's designed operating sequence, so the condition and installation of the gear should be checked during relevant maintenance work.
Continuous operation, mechanical loading, contamination, lubrication problems, or incorrect assembly may contribute to wear. However, the source of damage can vary depending on the engine's maintenance history and operating conditions. A gear should therefore be assessed alongside related components instead of being replaced based on a single symptom.
For the ZK6138 WP10.375 engine application described in the supplied parts information, the crankshaft timing gear is identified by part number 1005-00940. Before ordering, compare this number with the original component, the applicable engine parts catalog, and available identification records. This is especially important if the engine has undergone previous repairs or component substitutions.
Signs That a Crankshaft Timing Gear Needs Inspection
A timing gear inspection should follow the engine manufacturer's service instructions. Before beginning work, secure the vehicle, allow the engine to cool, and isolate the starting system according to the applicable maintenance procedure.
Several inspection points can help technicians evaluate the condition of the gear and identify possible problems elsewhere in the assembly.
Abnormal Wear on Gear Teeth
Examine the tooth surfaces for uneven wear, chipped edges, cracks, pitting, or other visible damage. Compare questionable areas with the expected tooth profile and the applicable service criteria.
Significant damage may affect how the gear engages with its mating component. If the teeth show unusual wear, the technician should investigate the assembly rather than assuming the gear is the only affected part.
Uneven Contact Between Mating Components
An irregular contact pattern may indicate an alignment issue, incorrect installation, excessive clearance, or wear in related components. The actual cause should be confirmed using the manufacturer's inspection procedures and specified measurements.
Installing a new gear without addressing a related alignment or mounting problem may allow the same type of wear to recur.
Contamination and Surface Damage
Dirt, metal particles, or other contaminants can contribute to wear in engine components. If debris is found around the timing gear, inspect the surrounding area to determine whether another component may be damaged or whether contamination has entered the assembly.
Cleaning and inspection should use methods appropriate for the engine components involved. Damaged parts should be evaluated against the applicable service requirements before reuse.
Mounting and Assembly Condition
Inspect accessible mounting surfaces and mating components for visible damage or abnormal movement. Installation position, clearances, and other assembly requirements should be checked according to the engine's service documentation.
Visual inspection is useful, but it cannot replace specified measurements where tolerances determine whether a component remains serviceable.
Why the Crankshaft and Related Parts Should Be Checked
Replacing a damaged timing gear without examining the surrounding assembly may leave the underlying problem unresolved. During an engine overhaul, technicians should assess the crankshaft, mounting interfaces, bearings, and other related parts as required by the manufacturer's maintenance procedure.
The supplied parts information identifies the following components:
1005-00940 — Crankshaft Timing Gear
1005-04165 — Crankshaft
1005-02261 — Crankshaft Flange
1005-00942 — Crankshaft Assembly, listed as including the gear and flange
These descriptions are important for purchasing. An individual timing gear is not the same supply item as a complete crankshaft assembly. Before placing an order, confirm exactly which component is required and whether the listed assembly includes the parts needed for the repair.
Bearing condition also deserves attention during an overhaul. The supplied catalog lists 1005-02120 main bearings as a set containing 14 pieces and 1005-04156 thrust bearings as a set containing four pieces. These parts perform different functions and should be inspected according to their respective service criteria.
Where wear is suspected, technicians should examine the relevant crankshaft journals, bearing surfaces, and mating interfaces. Measurements should be compared with the manufacturer's limits rather than assessed by appearance alone.
Connecting Rod and Bushing Inspection During Engine Maintenance
The crankshaft timing gear and connecting rod have different roles, but both may be included in a broader engine inspection. The connecting rod transfers force between the piston and crankshaft, while the connecting rod bushing provides a bearing surface at the relevant connection, depending on the engine design.
The supplied product information identifies 1000-00514 as the connecting rod. It also lists a connecting rod bushing under part number 1004-00296 in the source parts information. Because the product title references 1004-00286, buyers should confirm the correct bushing number against the original component or current engine parts catalog before ordering.
The listed quantity for the connecting rod is six pieces per bus. The bushing is listed separately, but its exact supply quantity and packaging should be verified with the supplier.
During inspection, look for abnormal wear, scoring, looseness, or damage around the connecting rod and its mating surfaces. Depending on the symptoms and repair scope, the piston pin, connecting rod bearings, and crankshaft journals may also require examination. Unusual mechanical noise or evidence of internal wear should be investigated according to the engine manufacturer's diagnostic procedures.
The supplied parts list also references the following related components:
1004-00188 — Piston Pin
1004-00835 — Piston
1004-01140 — Connecting Rod Bearings, listed as a set per engine
When an overhaul involves the piston and connecting rod assembly, these items should be checked against the actual engine configuration and repair requirements. Do not assume that related components can be selected solely from a general model name.
For buyers sourcing [ZK6138 Weichai engine spare parts], checking each number against the relevant documentation helps reduce the risk of ordering a similar-looking but unsuitable component.
A Step-by-Step Workflow for Inspection and Replacement
A consistent workflow helps maintenance teams organize inspections and avoid unnecessary parts replacement.
Step 1: Verify engine and component identification
Record the engine model, vehicle details, and existing part numbers. Confirm the 1005-00940 timing gear identification against the applicable parts documentation before purchasing a replacement.
Step 2: Document the original installation
Before removing components, record relevant installation details where practical. Follow the service manual for timing references, disassembly sequence, and handling requirements.
Step 3: Clean and examine the components
Inspect the gear teeth, mounting surfaces, and related parts using an appropriate cleaning and inspection method. Components that fail the applicable inspection criteria should not be reused.
Step 4: Investigate the reason for wear
If abnormal damage is found, examine relevant alignment, mounting, lubrication, and component-condition factors as directed by the service documentation. Replacing a damaged part without correcting the underlying cause may result in repeat maintenance.
Step 5: Confirm the replacement specification
Verify the part number, component type, supply configuration, and condition of the mating parts. During installation, follow the manufacturer's instructions for timing alignment, tightening requirements, measurements, and assembly sequence.
Step 6: Complete the required checks
Carry out the specified post-repair inspection and testing procedures before returning the bus to service. Confirm that the replacement is correctly installed and that identified underlying issues have been addressed.
This workflow is a general maintenance reference and should be adapted to the actual engine configuration and manufacturer-approved service instructions.
Preparing a Spare Parts List for a ZK6138 WP10.375 Engine
When several components are required for an overhaul, preparing a consolidated parts list can simplify procurement and inventory management. The quantities below are reproduced from the supplied parts information and should be verified before an order is finalized.
Part number Component description Listed quantity 1000-00514 Connecting rod 6 per bus 1004-00296 Connecting rod bushing 1, subject to confirmation 1004-00370 Piston rings, three pieces per cylinder set 6 sets 1004-00188 Piston pin 6 1004-00835 Piston 6 1004-01140 Connecting rod bearings 1 engine set 1005-00940 Crankshaft timing gear 1 1005-00942 Crankshaft assembly, including gear and flange 1 1005-02120 Main bearings, 14 pieces per engine set 1 set 1005-04156 Thrust bearings, four pieces per engine set 1 set The listed quantities are reference information, not a substitute for checking the actual engine and repair scope. In particular, buyers should clarify whether the requirement is for an individual crankshaft timing gear or a complete crankshaft assembly. Ordering both without checking the supply configuration could result in duplicate parts.
For workshops maintaining multiple buses, organizing requests by part number, vehicle, engine identification, and required quantity can make stock replenishment easier. Recording previous repairs and installed components also supports more accurate planning for future maintenance.
Sourcing Weichai Bus Engine Parts from Guangzhou Hangji Trading Company Limited
Accurate parts identification is essential when sourcing engine components for bus maintenance. Guangzhou Hangji Trading Company Limited was established in 2000 and is based in Guangzhou, China. The company specializes in Chinese bus spare parts and provides one-stop purchasing support for repair workshops, fleet operators, and parts distributors.
According to its company information, Hangji has more than 25 years of industry experience, a warehouse and shop covering over 5,000 square meters, a team of more than 30 professionals, and a catalog containing over 30,000 SKUs. Its stated services include purchasing advice, technical assistance from professional mechanics, and shipping by express, air, or sea, depending on the order requirements. Consolidated shipping is also available for orders containing multiple items.
The company reports that its core suppliers hold IATF 16949:2016 and ISO 9001:2015 certifications. Buyers can request relevant product or supplier documentation when evaluating components for their maintenance requirements.
When asking about the 1005-00940 crankshaft timing gear, 1000-00514 connecting rod, or connecting rod bushing, provide the engine model, exact part number, required quantity, and any available reference photographs. If a bushing is required, clarify whether the correct part number is 1004-00286 or 1004-00296 before confirming the order.
For broader overhauls, list each additional component separately and state whether the requirement is for individual parts or a complete assembly. This gives the supplier clearer information for checking the requested items and coordinating a multi-part order.
Inspecting the crankshaft timing gear is an important part of investigating abnormal wear and carrying out internal engine maintenance on a ZK6138 WP10.375 bus engine. Checking the gear teeth, mounting condition, crankshaft, bearings, and related components can help technicians identify possible causes rather than treating the gear as an isolated part.
Correct part identification is equally important during purchasing. The 1005-00940 crankshaft timing gear and 1000-00514 connecting rod are distinct components, while the connecting rod bushing number should be confirmed against the original part and applicable documentation because the supplied information contains two different numbers.
For replacement requirements, Guangzhou Hangji Trading Company Limited offers purchasing support for Chinese bus spare parts. Prepare the relevant engine details, confirmed part numbers, and quantities when making an inquiry to help check the required components and organize a suitable order.
http://www.hjbuspart.com
Guangzhou Hangji Trading Company Limited -
